Check the version of your usb hubs some kind of these hubs are not compatible with the new versions.
Does your External drive have a seperate power supply? Or does it get its power through the USB port.
If it gets its power from the USB port then by adding a hub you are essentially dividing the amount of power supplied by the number of ports extended.
One possible solution that could solve that situation would be to get what is called a powered hub. Which is exactly as the name suggests. The Hub has an external power supply so that it can provide even power to all of the ports.
I hope this helps
If not please post an update and I can try to find a better solution
If you need more help please post what Model of WD ext drive you have (ie....My book, Elements, Passport etc...)
Thanks,
Dave
