Question about Acer AL1717 17" LCD Monitor
Monitor Blacks out 'input not supported'
After using the monitor sometimes the monitor goes black and a message appears 'input not supported' the computer still runs but I have to shut off the computer and wait a couple of hours before I can turn it on again. I can't find the troubleshoot for this message. The power management is turn off-never and the screensaver is on off as well. What does this message mean?
  • 1 more comment
  • Chris Hetherington
    Chris Hetherington Jan 12, 2008
    My monitor blacks out ,only when I want to play a video file. It blacks out several times and either comes up with "NO INPUT" or just freezes.
    Tried a disc cleanup , registry fix, reinstalled win xp.
    Maybe Video Card is faulty?
  • sansou_sants Apr 23, 2008
    My acer al1717 monitor dead . problem power supply the fuse is burned and FL406 bridge rectifire shorted .it is repaired . after the moniter on screen displyed . few seconds the display is off the moniter standby. again the power button pressed the moniter on . few seconds display is off .iam checking all connections strips board drying power supply connection etc. how repare this problem plese help . my email is sansou_santsou@yahoo.co.in
  • bkirkbride Aug 30, 2008
    Can start up my computer without problems, and find that suddenly, maybe part way through a game, my screen goes black and a message appears, "Input not supported". The only solution is to switch off the main power, and reboot. I can do this straight away, and the problem goes away OK - until the next time it happens.
    Monitor - Acer 19" Norton is up to date, and I run RegCure quite often but it still occurs
I think the probelem is monitor resolution out of range . try the system resolution changes and connect the monitor then the issue is solved 80% or other problem is monitor hardware damages cheack the whole hardware components
Posted on Aug 03, 2009
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Sep 29, 2009 | HP w17e Monitor
BLACK MONITOR...INPUT NOT SUPPORTED
This is the resolution problem. Pls reduce the resolution . Right click any where on the desktop and click on properties there. a popup appears just choose Setting there . there you will find the option of Screen Resolution .Just Slide the pointer toward less litlle till your problem resolve.
Sep 04, 2009 | Acer AL1916W 19" LCD Monitor
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
Monitor blacks out...
You could connect it to a different PC to determine whether it's the monitor or video card, corrupted driver, etc....
Let us know how it goes, and we'll try to help.
Feb 08, 2009 | Dell E228WFP LCD Monitor
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Oct 30, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Princeton Monitor blackout
May I know how do make sure the connection is ok.. the only way to do is to use a known good monitor and connected to your system... this will tell you if you need a new one or not...
Aug 30, 2007 | Princeton Digital LCD1510 15" Flat Panel...
Acer AL1717 17" LCD Monitor Logo
335 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
