Question about Kenmore 22422 Top Load Washer
Water overfills and does not shutoff by itself to start machinee
Kenmore
    Scholar:
  • 112 Answers
It sounds like you have a faulty pressure switch. It is located in the top control panel. Sometimes, you can tap them and they will work (until they stick again.)
Posted on Nov 10, 2008
Siemens lady 130 dishwasher overfilling at start of wash cycle
There is a float at the bottom of the washer. See if it is stuck. It should move up and down freely. This activates the water shutoff when it reaches the proper level. If it is sticking it could allow the washer to overfill . If that is not the problem then I would look at the valve it activates itself.
Dec 31, 2014 | Siemens Dishwashers
Kenmore elite washer model 21082000, won't
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 19, 2010 | Kenmore Elite 21082
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water intake will not allow water to pass, does it have a flood safe cut off somewhere? How do I re set it?
Turn the water off going to the unit and turn the unit on with the water still off, then as the machine "starts " turn the water on very slowly, if you have no shutoff at the machine you will have to shut a main off. Just remember to turn on the water very slowly so it wont trip auto shutoff if it has it.
Nov 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore ref. water dispenser lock turns on itself & beeps
Behind the dispenser housing in the door is a small control board. It is messed up....could be from water getting on it or a voltage spike during a storm....but that is what controls your dispenser.
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenmore 22422 Top Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Robert Rankin
