Question about Rangemaster 110 (Gas) Kitchen Range
Oven flame ignites but will then not increase to the larger size
When oven switched on the flame ignites,but the flame refuses to go to the next stage to preheat the oven to the required setting.
  • Brasrus Nov 23, 2008
    I have a rangemaster 110. The main oven, right hand side ignites but the same remains at the same height and does not increase as it should when the oven control is in turned up.
  • Anonymous Apr 01, 2014
    Flame won't increase in size when you turn the knob setting Efel oil stove
When oven is switched on the flame ignites,butthe flame refuses to go tothe next stage to preheat the ovento the required setting
Posted on Nov 20, 2008
How do u replace an ingnition control board in a potterton boiler
see follow the next step:
Adjust an oven flame:
  1. Turn all of the appliance controls to off. Open the door and remove the oven bottom and baffle (see above).
  2. Turn on the oven and inspect the flame.
  3. Identify the air shutter that will be adjusted. It may be at the base of the oven burner, just above the safety valve, or somewhere along the gas delivery tube.
  4. Loosen the setscrew that locks the shutter or plate, and adjust the opening to increase or decrease the amount of air mixing with the gas.
  5. Turn the oven on again to verify the adjustment, repeating as needed.
  6. Once the flame is correctly adjusted, turn off the oven and tighten the setscrew.
Check and replace an oven spark igniter:
  1. Turn all of the appliance controls off.
  2. Open the door and remove the oven bottom and the baffle (see above).
  3. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  4. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Jul 31, 2012 | Heating & Cooling
Very small flame takes like ten minetes for flame to get high
The reason the flame in the oven is so small and takes for ever to heat up is because the oven igniter is weak and can not open the gas valve very much so hardly any gas flows resulting in a low flame size. By replacing the oven igniter the flame will be full size and heat quickly.
GENE
Oct 16, 2011 | Sears 61301 Gas Kitchen Range
Oven flame on right hand oven doesent increase when dials turned up
The OVEN flame size is consistently one size.
The thermostat simply stays closed longer when asking for higher temperature in the oven.
Sep 22, 2010 | Rangemaster Classic 110 (Dual Fuel) Dual...
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
The dial on my Avanti 24" oven is hard to determine which way to turn. When I hear the clicking sound, as the burners do, next I hear the lighting, whoom. Shall I start it at a low temp and then in a few...
It sounds like you are having an excesive buildup of gas pre-ignition. You should hear no "Whooom" sound.
The ignition assemble likely needs to be cleaned of rust, dirt, grease etc. That is the typical cause if improper ignition, gas buildup pre-ignition etc.
The problem of not staying lit is caused by either the flame sensor not sensing flame, (which may need to be cleaned or replaced.) or that the flame is simply being blown out by the air movement as a result of the sudden combustion of excessive gas build up.
So, to summarize, the ignition and burner assemblies need to be cleaned, and the flame sensor may need to be replaced.
Oct 12, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven flame and gril flame do not increase from starter/low flame setting. grill flame also splutters. seems not enough gas not getting through.
HI thanks for your question. the problem with your gas oven, is the igniter is not hot enough to ignite the gas. a common problem with gas ovens. replace the igniters. thanks the appliance doc. please rate my answer, if happy thanks-
Oct 14, 2008 | Kitchen Ranges
Rangemaster 110 (Gas) Kitchen Range Logo
452 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
