Question about Philips 32PW9523CG 32" TV
Philips 32PW9534 Power clicking
My Philips widescreen won't start, it just clicks a couple of times then the red light on the front starts flashing. I have checked the fuses inside, vacuumed it out and blown off the cob webs but it just keeps flashing and clicking. Any ideas please ?
3 Suggested Answers
  • 337 Answers
SOURCE: Power up then off, no picture, blinking red LED
The high voltage does come up but the set goes into shutdown because is sensing a problem somewhere in the set,the shutdown circuit gets activated when the high voltage is too high, a problem in the horizontal deflection circuit or because there is a problem in the secondary of the output transformer,this transformer helps develop voltages supplies and if one is missing the set senses the problem and shutsdown,there is another possibility and is related to the picture tube,there is a resistor in the crt board ,it should measure 51 ohms only ,sometimes it opens up and gives you same symptom.If you are familiar with tv service you can check this resistor and be alert of the other possibilities,if you are not too familiar be safe and get assistance from a servicer. Let Us know how it goes,or if you need more information.
Posted on Oct 26, 2006
  • 236 Answers
SOURCE: Philips 27PT6442/37 power
Sounds like you have a short in your power supply load. Probably the high voltage transformer and/or horizontal output transistor. Stargazer P.S. I've found that a lot of the newer sets are prone to high voltage transformer failure.
Posted on Aug 20, 2007
  • 267 Answers
SOURCE: philips 20ps47s301 turns on then starts clicking and turns off
Posted on Jan 16, 2009
0 characters
1 Points
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
Sep 13, 2009 | JVC AV-27920 27" TV
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Jul 31, 2008 | Standard (CRT) Televisions
Won't turn on
I have the same somewhere that it is a "motherboard" in the front of the TV...Still looking for the solution to this one.
Feb 13, 2008 | Philips 27PT81S 27" TV
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
Standard (CRT) Televisions Logo
127 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
