Sceptre x9 Komodo will not turn on. No light, power cable is good. Took apart, fuse is good - Power supply or logice board? How much for each? Thanks Jim
  • 105 Answers
I repaired one by replacing C107, 22uF electrolytic cap in the power supply.
Monitor Mike
Posted on Nov 28, 2008
The blue power light just binks when it's plugged in, the power button doesn't even have to be pressed. is that the power supply or the logic board? (already ruled out inverter board)
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
Jul 15, 2010 | Sceptre Komodo X37SV 37 in. LCD Television
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Scepyre 17 in X7
This board is out of my Sceptre X9G Komodo. The 740uf capacitors are clearly marked 25V. The 1200uf Caps are 10V. I ordered parts for mine to try. The darker 740 has a slightly "popped" top.
470 is about 10mm dia X 16-17mm long
1200 is about 10mm dia X 20? long
two leads on each about 5mm apart. They are soldered to the board.
Jul 16, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Dead scepter x22 monitor
Had a Sceptre DCL9A model for mine. There are plastic snaps which hold the back and front covers together. After I took off the screws and detach the monitor stand, I slid a very small flat head screw driver along the sides until I found each snap. They should come loose easily with a slight twist of the screwdriver. There are about 5 on each side of the monitor (not counting the monitor). Do not try to force it as you can warp or crack the plastic.
Jun 22, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
X9g komodo v screen just turned blank (white)
Go to ebay, type X9g kimidi logic board. Usually, some seller might have pulled working parts from other monitors and sell them individually. If you cannot find them, google "buy x9g komodo logic board". Some website, I'm quite sure will sell them.
Mar 17, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Flashing green power indicator lamp.
Check out the data plug- you may have bent some pins.
May 31, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
