Question about Alba DVD-108 DVD Player
My alba dvd108 player refuses to play some specific dvds says that cd is rated and asks for pasword to continue.i have read the manual about reseting to default settings(password7890) but so far the dvd still says 'RATING ERROR'.when i check the set up for rating it has been set at 1(KIDS),I have tried to change the rating to 8(ADULT) but the player still asks for a password.Since i have never put any password since i bought the dvd ive tried putting the default password from the manual i.e 7890 but the message i get is 'rating error' please assist me on how i can change the rating from 1 (KIDS)to 8(ADULT).I would really appreciate it if you could help me solve this problem otherwise the player is reliable. thank you . cyrus wanjohi
3 Suggested Answers
SOURCE: I need the the code to enter in a Tevion URC-48B
I have a APEX DVD need the code to conect item 10210.
Posted on Jun 11, 2009
  • 3153 Answers
SOURCE: i have a region 2 dvd player and i want to play a
Some players are harder than others to do this but you may want to try here or here
Posted on Sep 13, 2009
  • 270 Answers
SOURCE: trying to set up my
The code depends on TWO factors... the equipment you are trying to program, and the type of remote.
Here is some useful info:
Posted on Sep 26, 2010
0 characters
1 Points
Trying to set up my universal remote. There are dolby list, I have a dolby digital dvd. I need a code for the dvd. I hope you can help me. Thanks Mr Cyrus
Sep 26, 2010 | Alba DVD-108 DVD Player
Alba dvd 174 specification. what file types can be played through this dvd player?
Your Alba Dvd player should play the following types
DVD, DVD-R/RW, DVD+R/RW and JPEG. Along with good old CD's
Aug 02, 2010 | DVD & Blu-Ray Players
Will play region one dvdon this dvdv player
According to the spec sheet, the Alba 113 dvd player is a region free device. This means that it should play dvds from several different regions. So, to answer your question, yes, it should play region 1 dvds. Good luck! Der Strom
Apr 12, 2010 | Alba DVD-113 DVD Player
Code for bubble console
the codes in the book are
0768 0770 0831 0881 1097 1115 1165
Dec 09, 2008 | Alba DVD-108 DVD Player
Lg da3520 home cinema system refuses to play DVD discs. It has no problem playing CDs but DVDs it either says "Check Disc" or "Disc Error" or continues to attempt to load the disc but...
you have probably to clean up your dvd player with a clean up CD. After that if your dvd player doesn't want to read a dvd but play a cd, your laser output must be to fix. you'll have to go to a specialist.
Apr 23, 2008 | DVD & Blu-Ray Players
Alba 3450 tvd
some dvd players do not have the REGION CODE set until the1st disk is put in. The region then is set to that disks region.
Feb 16, 2008 | Alba DVD-108 DVD Player
Alba dvd
check on the system menu under preferences, there is a option there if that helps
Dec 22, 2007 | Alba DVD-108 DVD Player
Region free codes for alba dvd 108
Oct 20, 2007 | Alba DVD-108 DVD Player
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Alba DVD-108 DVD Player Logo
53 people viewed this question
Top Alba DVD & Blu-Ray Players Experts
Are you an Alba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
