Question about NEC MultiSync MT1030 Multimedia Projector
Looking for NEC MT1030 Servicing Software (Ser1035.exe)
Hello all- We have a need for the NEC servicing software. It's listed as simply "ser1035.exe" in the service manual. Any help would be greatly appreciated.
2 Suggested Answers
  • 1833 Answers
SOURCE: Need "Service Menu" passcode for NEC GT1150
There is no code as such. Please decsribe your problem so that, we can help you.
Posted on Dec 20, 2010
  • 17129 Answers
SOURCE: Hello does anyone have a service manual for an NEC
Please check the link for the manual:
Posted on Nov 08, 2011
0 characters
1 Points
I have a u260W and now it shows white spots all over. what could be wrong and what could be done
DMD or DLP chip has died. Can be replaced by user if you have electronics experience equivalent to building or servicing desktop computers. Just replaced mine this week, actually. Good as new now. The part or chip number is on the chip itself. Once you have that number, you can usually find replacements on eBay for roughly $200. Kinda pricey, but way less than a new unit. I looked at some forums but found no listed DMD chip numbers for your projector:(. Hope this helps!
Mar 31, 2014 | NEC Multimedia Projectors
I'm looking for the NEC NP3150 service manual. not the user manual. unit won't turn on due to overheat error code. isolated it to temperature sensor fail... not to true overheat issue... need to buy a...
I have the temperature sensor, I will send it to you ,if you need
the unit price is USD70 ,and the freight is about USD30
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Feb 24, 2014 | NEC NP3150 Projector
Vt491 service manual
Are you looking for it or do you have the service manual?
Jan 17, 2013 | NEC VT491 LCD Projector
How do I angle the projector at the side of a screen & get the screen view of it straight?
In projector menu you will find a setting called 'keystone correction'. Use horizontal and vertical keystone correction to correct the projected image.
Sep 24, 2011 | NEC MultiSync MT1030 Multimedia Projector
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have...
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector helpful, where the owers manual for the MT 1030 is available in PDF version.
May 13, 2010 | NEC MultiSync MT1030 Multimedia Projector
Picked up a NEC MT1030+ on a gov auction with NO REMOTE. Lamp hours have exceeded the 2100 and projector is shut down. With out remote, how do I get it back on?
Hello, Paul.
You don't need the remote to power on the projector. There are front panel controls that power on/off.
The problem is that you need to replace the lamp. The lamps cost $200 +, USD.
Hope this helps.
Mar 14, 2010 | NEC MultiSync MT1030 Multimedia Projector
Strange shadows on NEC MT1030+ projector image
I dont know if this helps but I have of few of these at my company and when I had the repair people out they said it was a bad prism. If anyone can repair these and whats to buy them cheap let me know.
Feb 24, 2008 | NEC MultiSync MT1030 Multimedia Projector
Where is the usb driver in web
Pls Check at for the driver and must tell that you got it or not. I will send the file to you.
Rave Services India
Feb 07, 2008 | NEC VT460 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
NEC MultiSync MT1030 Multimedia Projector Logo
100 people viewed this question
Top NEC Multimedia Projectors Experts
Electro Med Services...
Are you a NEC Multimedia Projector Expert? Answer questions, earn points and help others
