Question about Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
How do i measure the exact watts going to my sub woofer in my car. The amp I am using is a sony xplod xm-1652z amp. I have a light connected in between the amp and sub and want to know what watts the light is receiving
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Posted on Dec 21, 2008
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a sony xplod 1652z 1000 watt amp and want to hook up 2 subs and the speakers that are already installed in the truck is that possible?
thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
Jun 10, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a Sony Xplod XM-1652Z 1000 W. I am using it to power my 2 Infinity 10" subs with 1052 watts on each Max. My problem is that when i turn on the volume too high the subs would stop working. My friend...
Sony audio products are not worth the buck, you will be facing worst problems in the future, my advice is just to change the amps. It is causing the problem, it cant handle frequencies when volume is turned up. and it may say 1000 watts but actually this is the peak rating your amp can handle thus meaning that it couldnt handle constant high volume usage, try crunch, kicker or hifonics amp, and look at the RMS rating on the amps when shoping.
Mar 31, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
123 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
