Question about Logitech MX Revolution 931689 Mouse
New mouse wont connect....
My new logitech MX™ Revolution will not connect to my computer but my old dynex will and both are wirelss what do you reccomend i do to hook it up
  • torqie Dec 10, 2008
    tried the reconnect utility and mouse is charged and it did not work. Tried uninstalling usb ports and starting fresh with a fresh install and still wont work. Maybe my mouse is defective.. it used to work GREAT!
  • Javi Napalm Candy
    Javi Napalm Candy Jan 19, 2014
    I had exactly the same problem.... it is maybe a programed obsolescence?
    Problem Solver:
  • 4 Answers
This is a common problem, go to the Logitech website (www.logitech.com) and download the Reconnect utility. Follow the steps given to you in the software and it should work fine! If not, is the mouse fully charged?
Posted on Nov 16, 2008
Logitech mx revolution
Hi
Maybe your registry is not clean. You can use registry fixing software and then run registry analyze. and restart your computer.
Jan 19, 2014 | Logitech MX Revolution 931689 Mouse
Back button, forward button does not work on my mx revolution mouse
Problem was solved by remove usb connection and reconnecting. All buttons work now. Thanks
Nov 03, 2009 | Logitech MX Revolution Wireless Laser...
Keyboard keys not working, sluggish mouse
You might need batteries. Manufacturer-supplied batteries are frequently low quality. So, try that.
Oct 16, 2017 | Logitech Cordless Desktop MX 5500...
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Mx revolution mouse
make sure it's clean where the light sensor is. Dustbust it or something. otherwise I'd say it's dead.
Jan 31, 2008 | Logitech MX Revolution 931689 Mouse
Laser Mouse MX 1000 By logitech
try replacing with new rechargable batterys
Nov 03, 2007 | Logitech Cordless Mouse
Logitech MX Revolution 931689 Mouse Logo
770 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
