Question about Sharp AL-1000 Copier
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
My Sharp AL-1340 when copying the scanner hangs up, I hear a grinding -type sound, the ready button flashes and the screen shows a flashing E 7 code.
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Posted on Nov 11, 2008
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
Repairs of sharp AL 1000 flashaing E and 7
The scanner is not reading the white reference strip under the glass properly. You will need to clean or have cleaned the scanner optics and at least the white strip under the original glass. This strip is located under the left edge of the glass...under the scale that has the original sizing on it. The machine uses this strip on start up to reference the scanner. Simple fix.
Oct 21, 2009 | Sharp AL-1000 Copier
Sounds like the scanner is locked. Look under the scanner where the paper comes out, there is a clear wheel, turn it all the way one way or the other and that will unlock the scanner.
Err0r l1 00
If you hear any cracking sound if you are not please clean all surface scanner area.Clean scanner sensor
unlock position .
Oct 07, 2009 | Sharp AL-1655CS Laser Printer
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Error on sharp copier
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
May 19, 2008 | Sharp AL-1000 Copier
Sharp AL-1000 Copier Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
