Question about Panasonic NV-FJ700AM VHS VCR
Suggestion I got new problem in NV-FJ700AM model, i.e. AV1 & AV2 Input Right side audio not acception & there is no Right side audio out. But in Left side working ok. Please give me suggestion for service
  • 71 Answers
It seemed to have a problem in the audio preamplifire ,if you know how to just open and check any dry soldering terminal at the audio amp. board regards please don't forget to rate ,thx
Posted on May 04, 2007
Can't get a dvd to play. all input sources say no signal. where is the yellow video input? which input source should i use?
You can use AV1 or AV2 depends on the make and model of the TV you have. You should hvae THREE RCA plugs from the DVD (Yellow for the Video, Red for right channel audio, White for Left channel audio) You just have to match the colors at the TV and the DVD player.
What is the make and model of the TV?
Aug 26, 2011 | Televison & Video
I hook everything up to the tv for the nintendo 64, but I still have no picture on the tv or audio. Help!
make sure your cords are in properly. You may have to get a new set of cords from ebay or your local electronics store. Also NOTE: Most TV's have AV1, AV2, Component, then Cable. AV1 and AV2 are both ports(usually on the sides and back), thatyou plug the audio and video into. Make sure both of these have no video or audio before you go out to purchase new cords.
Hope this helps!
Aug 09, 2010 | Nintendo 64 Console
AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
I can not select input source, even though AV1 is connected. Pressing INPUT button has no effect. All I can see is ''Not connected to the camcorder'', which is true - but I want to record from AV1.
Press INPUT repeatedly to select the external input
to record from.
AV1: Audio/Video Input mounted on back panel.
AV2: Audio/Video Input mounted on front panel.
DV: DV Input mounted on front panel.
DV IN jack.
This recorder is only compatible with DV-format
(DVC-SD, DV25) camcorders. Digital satellite tuners
and Digital video recorders are not compatible.
Make sure your cables are connected correctly, if an audio cable is plugged into the video the unit wont see it.
Sep 05, 2009 | LG RC897T DVD Recorder/VCR Combo
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Panasonic NV-FJ700AM VHS VCR Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
