printer will display intializing on screen for a few seconds then it automatically shuts off. Changed all ink cartridges after display showed missing ink cartridges. After changing cartridges printer did not work
Is it an easy to replace the scanner assembly on an HP 3380? Machine works fine otherwise. Is it...
(More)
Is it an easy to replace the scanner assembly on an HP 3380? Machine works fine otherwise. Is it worth the $180 for the part if I install it?
Just acquired this monitor from a friend...Opticlear..MultiSync 90GX2 from NEC. Everything has...
(More)
Just acquired this monitor from a friend...Opticlear..MultiSync 90GX2 from NEC. Everything has slight, but letters and numbers most pronounced, ghost. Can this be fixed without cost?
When I try to print a page the printer makes sounds like it wil print a page but does not produce...
(More)
When I try to print a page the printer makes sounds like it wil print a page but does not produce anything.
I put new color (cyan, magenta, and yellow) ink cartridges. Since then I cannot get colors correct....
(More)
I put new color (cyan, magenta, and yellow) ink cartridges. Since then I cannot get colors correct. Most often it prints yellow. No red, no blue. Another purchase would be $120 and then I'm not certain it would solve the problem.
