I have 5.1 Denon AVR-486 surround sound unit. The center speaker sounds tinney and the side and back speakers are not pushing big volume. I have 3 bose in the front two on the sides and two polk for my rear speakers. I am hoping you can recommend what I need to do to maximixe my volume.
  • GeekaRama Nov 11, 2008
    so does it mean i need to replace these most expensive speakers? Or simply adjust the impedance output from the receiver to match the output simulating what the factory speakers had.
    I am sorry but not following the comment with regards to the acronymns and traveling sound. I do how ever understand connections and all speakers have been triple checked. Can you explain to me in Laymen terms how I can trouble shoot? I think we should start with the impedence question I replied and go from there.
    Brigadier General:
  • 6,966 Answers
Initially, pls do a passive resistance check with all the speakers using a DVM or a VOM. Often speakers would either be 4 or 8 ohms.Thereafter, pls verify that the polarity of the speakers, their speaker wires and how they are attached to the receiver are maintained. Additionally, you may to check for the physical travel of the speaker coil/cone and check if it is moving freely within its confines by lightly pushing and visually checking their action. If all the speakers checks out as well as the wiring and how they are connected, then most likely fault would be with the Denon AVR-486.
To my knowledge, the Denon AVR-486 has 7 separate amps but all of them are rated equally. You may want to cycle the DSP Surround Modes. If problem is common in all settings, then presumably a pair or more of the amps would need looking into. Additionally, you may want to double-check consistency of the speaker arrangements/connections at the rear.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • 19,396 Answers
Check that all speakers have same impedance, if speakers are different , thet is probably the cause.
  • Ginko
    Ginko Nov 11, 2008
    Using speakers with different caracteristics on a surround system is generally no good.
    When you use different speakers on a diffusion system like your surround, you must ensure that at least they have same impedance.
    Even with same impedance, speakers like the Bose should not be used in conjunction with other speakers, that is probably the cause for your bad sound distribution.
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Denon AVR-1403 connected to DVD can hear music but no dialougue!!
Check the center channel speaker and the surround sound audio settings. If you do not have a center speaker, it needs to be set to off on the receiver.
Jan 19, 2009 | Denon AVR-1403 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
B Speakers: Rear A Speakers and Sub stay on
First, check you wiring. Have you tried to turn off all speakers then turn on only the "B" set?
Might also be your "surround" settings. Try a "2" channel mode if available.
GL!
Aug 09, 2006 | Denon AVR-1604 Receiver
52 people viewed this question
 Grubhead
Grubhead
