Question about Sony KP-48S75 48" Rear Projection Television
Blown fuse? My sony rear projection 48in is about 6 years old. I have had no problems untill the other day while watching it it just went "pop" and lost ALL power. It acts like its unpluggeg. Where are the "fuses" to check? Any other suggestions? thank you
  • 4 Answers
Your problem is that the power supply of the tv went out and it wasn't beacuse of a bad fuse. need to take it to a tech service to check it.
Posted on Nov 06, 2006
I turned the TV on, a mild 'pop' sound, and it immediatly shut off. Now it won't power on at all. Is it worth fixing? Its 11 years old (July 1998). Thanks for any advice!!
you may have just blown a fuse. check and replace with same size and type. if you smell burning, you fried something, and it may not be worth replaing on a 11 yr old tv.
Jul 31, 2009 | Hitachi 50UX58B 50" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony Trinitron WEGA won't turn on
6 blink error is either a power supply (g2 board) or a blown thermal fuse. if it came back on, its not the thermal fuse so you would need a new g2 board. if it blinks 5 times, you need a new ballast (lamp driver)
Dec 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
Pop then dark screen - no picture... New lamp installed and still no picture
Yes you are correct, I have seen this many times. 6 flashes is the thermal fuse
Mar 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
HELP
MY PC HAS A PROBLEM OF DOWNLOADING DRIVER. HOW CAN U HELP ME GET THE DRIVER?
Jan 30, 2008 | Samsung PCL545R 54" Rear Projection...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Rear Projection TV
high humidity could be a cause i have a similar problem with a sony rear projection. on some warm rainy days /try cleaning lenses with a photographic anti fog cloth.but be very carefull not to scratch or leave dust on lens.
May 08, 2007 | Mitsubishi WS48511 48" Rear Projection...
Sony KP-48S75 48" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
