Question about Bose LifeStyle 5 Series-III CD Shelf System
Schematic and Service Manual for Bose Lifestyle 5/12
David, read your solution of replacing C19 (33uf, 63v) capacitor on Lifestyle 5/12 to fix display problem. Tried it on my unit and the display now works. Do you know were I can get the schematic/service manual for this unit ?
Thanks,
Specialfolks (Herb)
  • chogan Feb 15, 2009
    I have this same problem. Everything works fine, but no display. Could you help me understand what needs to be done to fix it?
althoffk
  • 4 Answers
SOURCE: Bose Lifestyle
I have a service manual with complete pcb layouts and circuit diagrams, contact me in case someone is interested.
Posted on Jan 16, 2009
SOURCE: bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Posted on Aug 02, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
No display lights on bose lifestyle 8 home theatre. System works though.
Displays die quite often on receivers just one of those things that happens.
Bose is pretty good about repair cost and timely in their turnaround. Here is a link to the support page
I would guess a replacement display would run about $150 installed plus you will have to ship your unit to them.
They like to do "flat rate" service plans which is one of those 50/50 deals most of the time you are better off just paying for the repair versus dealing with a service contract but you will have to find out whats available for your model.
Hope that helps
Feb 12, 2010 | Bose Lifestyle 8 series II System
The display stopped working on my Bose Lifestyle 12 Home Theater system.Any Ideas on how to fix this???
i did have encounter the same problem!!!! what i did was have the whole capacitor replace ! I didn't bother to have them check beside its will cost you less than $10 this is how a capacitor will look like http://www.allproducts.com/manufacture97/qiyu/product1.jpg . check the ( + )positive ( - )nagative by marking either one on the PCB board before you proceed! very important! good luck
Dec 04, 2009 | Bose Lifestyle 12 System
I own a Bose Lifestyle 12 system and the display on the console has failed. All else works (ie: buttons and remote.) Is it possible to have it reasonably repaired, DIY or must I live with this as is? Thank...
Its working lifestyle 5, 8, 10, 12 receivers Its Easy fix you need open it up and on lover left corner on bottom first capacitor value 3.3uF needs to be replaced.I did all ready 3 units and its all work now
Oct 28, 2009 | Bose Lifestyle 12 System
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 20 very Dim display
There are instructions available at www.AnyoneCanFixIt.com that has detailed pictures of this repair, step by step.
Jun 23, 2009 | Bose Lifestyle 20 System
Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Apr 01, 2009 | Bose Lifestyle 12 System
Everything works with my bose lifestyle model 5 music center but the display wont light up. Do I have a bulb out or something ? How can I fix this, its driving me nuts! Thanks for any help you can give....
According to other threads this is due to a bad capacitor (either C19 or C16). It is a 33uF capacitor rated at 25V. Needs to be replaced by a 33uF higher voltage (like 63V). Have the same issue but have not yet completed the fix. Please perform a search on the forum and you will find it. It says is on the lower left side of the console pcb.
Dec 20, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5 ~ dead display fix
Hi the fix for a dead display is a faulty capacitor. Depending upon which board version you have, you need to replace the 33 uF / 63 volt capaitor. On some units this is C19 on the display board, on other units this capacitor is mounted on the main board and re-numbered, there is only one 33 uF on the unit so you should be able to find it.
Dave
Sep 21, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Aug 16, 2007 | Bose Lifestyle 12 System
Bose LifeStyle 5 Series-III CD Shelf System Logo
1,962 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
