Question about Cook's Essentials Smoothie Maker Work Top Blender
COOK'S ESSENTIALS BLENDER CESS700B GASKET
I HAVE A COOK'S ESSENTIALS BLENDER CESS700B AND I NEED TO FIND WHERE TO GET THE GASKET FOR MY JAR.
    Problem Solver:
  • 5 Answers
Go to: http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3694&secid=53&linkon=category&linkid=91 My Cook's Essentials is just like the Back to Basics model SE 2000. Yours may be one of the other models, click on replacement parts at he top. I hope this works out for you too.
Posted on Feb 12, 2009
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
What is the phone number for Cook's Essentials
The only contact telhone number I have is 1-800-233-9054 for cunsumer service.
Apr 06, 2012 | Cook's Essentials CEM848 Handheld Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
Need a replacement gasket for the Cook power blender
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
Mar 03, 2011 | Cook's Essentials Smoothie Maker Work Top...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Cook's Essentials Smoothie Maker Work Top Blender Logo
1,798 people viewed this question
Top Cook's Essentials Blenders Experts
Ross Keen
ray gallant
Tom Chichester
Are you a Cook's Essentials Blender Expert? Answer questions, earn points and help others
