Question about RCA D52W19 52" Rear Projection Television
Bowed at top and bottom
Rca hd52w59yx39....picture is bowed at top and bottom and i can see the red and green and blue at top and bottom...however the tv was vandalized and hawaiin punch was poured all over it...a tech came out last year and cleaned it...didnt replace parts cuz it was recently purchased but said that it may do this type of thing again because he couldnt get all the juice out of it...now that time has come again...wat can i clean to get my picture back to normal...i have canned air and electronic cleaner...please help!
  • RCA Master
  • 5,138 Answers
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Posted on Nov 10, 2008
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
My 51" rca flat screen tv is on all inputs make everything red, green, and blue. how do i fix this?
The sympton you describes points to a convergence issue. Is the picture 3-d looking? is the picture bowed in at top and bottom? Can you get the menu to display? I offer a suggestion ... read the article named fl231 fuse in the tips and tricks section of this website. http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
then let me know if i can help you further. i have seen alot of rca in the shop.
ps. what is the model of this set?
Oct 13, 2010 | RCA Televison & Video
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
