Question about HP DesignJet 750c plus InkJet Printer
Cartridge path our hp 750c e/ao plotter cartridge goes back and forth several times and then it stops. the message board says to switch power off and check cartridge path we don't see any obstructions and just recently replaced the drive belt and the encoder strip any thought or ideas would be appreciated
  • Anonymous Feb 17, 2009
    Lowere
  • 53 Answers
By it going back and forth means all is ok with the encoder strip. Sounds like its asking for a bit of lubrication. There is a special oil available from HP for the carrage. This also works for tha large format machines using plastic bushes such as 500, 800, T610, new 510 etc.
Posted on Feb 06, 2009
750c plus was turned off and now says printer cartridges missing
Pull out the cartridges, turn the plotter on and install the ink cartridges one at a time - making sure each one is recognized. One of them may have gotten a power surge and had the electronics burned out - - replace that cartridge with a new one.
Mar 28, 2013 | HP DesignJet 750c plus InkJet Printer
Everytime I turn on the designjet 750c plus, it tells me to turn power off and check cartridge path.
Make sure you have the correct cartridges and that the tape has been removed.
You can try a new set of cartridges and see if that solves your problem.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | HP DesignJet 750c plus InkJet Printer
My HP750 plotter just displayed the message, "Switch Power Off; Check Cartridge Path" after the last print job. I see nothing blocking the printer cartridges and can't get the message to clear. Am I...
I've seen this error on the Designjet 750 plotters. Basically the plotter puts out this error if the carriage assembley cannot move along the Y-Axis (back and forth)
The carriage moves along the Y-Axis driven by a motor with a metal gear, pushing and pulling a rubber belt. Over time the interaction between the metal and rubber causes the teeth to wear off the belt and often times the worn rubber gets stuck in the teeth of the motor gear.
So, open the cover, and look behind/below the carriage itself and find the belt which runs the width of the printer. Run your fingers along the tooth side of the belt and check for degraded teeth, aslo examine the metal base below for any debris If you find debris, this is your root cause of the error you are getting.
Unfortunately, changing the belts on these machines is quite a process; on average it takes me 3 hours to replace a belt (and I've done dozens of them) It would be best to find an experienced tech since there can be some difficulties when replacing the belt (specifically proper belt alignment, and the removal of the side covers can be tricky as well.)
If you do not have any debris, and the belt is degraded, it could be that the motor which propels the carriage could be bad or something is obstructing the movement of the carriage head (the ink supply lines, the pen path, or media could be the issue).
Aug 18, 2009 | HP PSC 750 All-In-One InkJet Printer
DesignJet 750c Plus System Error 040502
The bad news is that this seems to be a fatal error of the main board. The only time I have had a similar error is when the carrage motor shorted out and blew the main board. This probably did not happen in your case but something appears to have taken the board out. The main board is speculation, but I think I am correct, sorry, Dave
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
Help fix my HP750C, clear carriage path message
Sounds like it can not find home. Is there a limit switch? If not there may be a failure in the counter from the stepper motor.
May 24, 2009 | HP DesignJet 750c InkJet Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
Printhead
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
Oct 17, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
469 people viewed this question
Ben Johnson
