Question about Cell Phones
I am unable to back up the information on my PC onto my mda vario 2 using active sync
    Brigadier General:
  • 7,752 Answers
Try the software cd that came with the phone if any or try the mobile website
Posted on Nov 10, 2008
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
T mobile mda vario 2 of USA and now I want to use it in india so for that i need network unlock code
u can find info via this thread!
http://forum.xda-developers.com/forumdisplay.php?f=254
Mar 03, 2010 | T-Mobile MDA Vario II 1000 Smartphone
How do i unlock htc wiza200 mda
There is a very straightforward solution now, thanks to some helpful peeps at xda-developers forum. Simply download a zip file called lokiwiz3a.zip (Google is your friend).
I used it yesterday and had generated the unlock code within minutes of connecting the MDA Vario with my laptop.
Oct 12, 2009 | T-Mobile MDA Vario II 1000 Smartphone
Deleted text
it depends on whether you sync your phone to a pc on a regular basis and backup your data. Unlike a computer which you can just restore to a previous date and be able to access uncorrupted or deleted data, I believe a cellphone deletes any information that you physically delete. I had a MDA Vario and there was a trashbin where you could access deleted stuff if you hadn't emptied trash, but if you don't have this on the android, i dont think you can access that info if theres no backup that you initiated on a computer.
May 25, 2009 | HTC G1 Smartphone
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
May 13, 2009 | T-Mobile MDA Vario Smartphone
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
Aug 16, 2008 | T-Mobile MDA Vario Smartphone
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
