Question about RCA F36689 36" TV
Guide menu comes on with set turn on.
When turning on thr set with the "TV" button, the Guide program menu comes on . This just began two days ago. What gives? By the way, thanks to reair guy for solving my audio problem. RCA F36689 36" TV
  • 3130 Answers
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Posted on Oct 16, 2007
Your code for rca is10047.
Posted on Oct 30, 2007
Try this;
It gives you a step by step instruction on how to turn the Guild off.
Posted on Feb 11, 2008
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: rca 27v414t shut off by it self after a feww seconds.
After replacing the flyback transforer and horizontal synch transistor you will need to adjust the flyback transofrmer as follows:
Turn each setting to just above mid point clockwise, turn the tv on and you should see a white screen with retrace lines in it just before the tv turns back off. set yourself up with a plastic screw driver and prepare for adjusting the focus(top adjustment) turn the tv on and adjust the focus by looking at the pixels on the screen. repeat as needed to complete.
Next setup for the brightness (lower adjustment) turn the tv on and adjust the brightness to where the screen appears to be black(no haze or lines). After the tv turns off wait a few seconds and turnit back on, it should stay on, if not then the brightness setting it too far one way or the other and "TecniklyNuts" it correct, the system detects the setting out of range and turns the tv off. Repeat the two adjustments until the system stays on.
Posted on Feb 08, 2009
  • 4721 Answers
SOURCE: I have an 2001 RCA TV model F31317 it has a Guide
You can disable this only by going into the Guide Plus+ menu. If you have the original remote or one that matches the feature, press Guide then Menu (sometimes you need to hold this for a few seconds), navigate to Setup (right arrow until it is highlighted). OK, Menu or the down arrow all let you enter the menu. Then use the up/down arrows to select Review Options. Select Off (only two choices). Press OK and exit the guide.
I hope this helps.
Posted on Oct 02, 2010
Testimonial: "Thank you Cindy! I did not know that menu existed. You have been very helpful!"
0 characters
1 Points
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Standard (CRT) Televisions
When I turn on my internet and TV with the universal remote the Guide Plus menu comes up as well and we can't get out of it without turning the TV off then on again manually. Is there anyway to program the...
1. When you cut on you tv the guide pops up.
2. On the tv remote there is a button that says "menu" hit that and the screen should go away, i just did it myself because i have my tv program with that Jumbo Universal Remote Control and just ran into that problem.
3. How to just program it out of the tv when its cut on all together, im on the hunt for that answer myself.
4. Try going to manufactures website and try trouble shooting for your make and model, that is what i am about to do right now. Cable tv has the guide so i don't need my tv to pop up its guide also.. you now.. good luck
Jan 05, 2009 | RCA 24F512T 24" TV
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
Jan 01, 2009 | GE 32GT740 32" TV
Small rca truflat tv won't turn on
the problem is that the tv was probably set to pwr on only with remote control.........i have the same problem and lost the remote...........BUMMER! Trying to figure out how to reset the programming without the remote.
hope that helps someone!~
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Rca truflat locked
Hey this same thing happened to me not too long ago and you just have to buy a Universal remote and program it (it should come with the codes to program it to your TV) I think the code is 704 or 702 for RCA... Anywho after that then you can turn your tv back on wit the remote and push menu and Preferences and then FPA off. Its just a parental control block so your kids cant touch the tv buttons and mess with your settings.
Sep 25, 2008 | RCA TruFlat 27F520T 27" TV
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
RCA F32450 TV
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
Guide plus and main menu problems!
One of you control buttons may be stuck. I found this problem once.
Dec 17, 2006 | RCA F32444 32" TV
RCA F36689 36" TV Logo
16 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
