Question about Zebra P330i Thermal Card Printer
Zebra p330i ribbon snapping after sticks to card
The printer has been idle for about a year. New ribbon was put in, new cards put in, short and long cleaning cards were done.
I did not clean the rollers/head directly, as we do not have the foam cleaners.
Any other suggestions?
Thanks
  • ggallen Nov 11, 2008
    Well, aparantly, I needed to clean the track area and the rollers. After that the sticking/breaking of the ribbons stoped. I also downloaded the most recent firmware/driver which allowed me to recalibrate the ribbon.
    This step solved my problems.
5 Suggested Answers
  • 8 Answers
SOURCE: What does a Polaroid p85igc card printer use for a
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Posted on Dec 15, 2009
  • 4 Answers
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
ozztech
  • 285 Answers
SOURCE: Zebra P330i out of ribbon
Send a command "!SA" The printes go recalibrate it self, don't forguet to put a card on the feeder.
Posted on Nov 12, 2010
ozztech
  • 285 Answers
SOURCE: have problem wiht zebra p330i
send !SA command from the driver to calibrate.
Posted on Nov 13, 2010
ozztech
  • 285 Answers
SOURCE: Zebra p330i
lose the two screws from the front plate, put a card under the printhead, ajust the plate on tope of the card, tie the screws. send a command !SA from the driver, and print a test card (send IM command)
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
Zebra P330i out of ribbon error message but there is still plenty of ribbon
Oct 26, 2010 | Zebra P330i Thermal Card Printer
Zebra p330i
Jun 21, 2010 | Zebra Eltron P330i Card Printer
Out of ribbon p330i Zebra
possible need to recalibrate the sensors, go to driver, and send the command !SA.
May 06, 2010 | Zebra P330i Thermal Card Printer
Keep getting broken ribbon message on zebra P330i printer
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Zebra P330i Printer not counting the YMCKO ribbon correctly
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
Jul 16, 2009 | Zebra P330i Thermal Card Printer
Card cutting ribbon on Zebra P330i
On the front of the head. 4 screws are there.
Near the head where the ribbon contacts the card.
Loosen the top 2. Let the metal guard slide down a bit. Tighten the screws. Try a card.
Keep adjusting the guard until you tune it right.
Sketchlab.com
May 13, 2009 | Zebra P330i Thermal Card Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
P330i card printer
Just a note, you need to be careful when sending the !SA command, as in some of the earlier firmware versions pre v1.16.11 , it can "double count" the i-series chip contained in the ribbon. So for example if you run the !SA command with a new ribbon with 200 prints remaining, it is possible after 100 prints the chip has counted down and the printer displays "OUT OF RIBBON" even though you have half a ribbon left.
I would use the following procedure to recalibrate the colour sensor only:-
1). Remove ribbon and lock the printhead down
2). Send the command !CSA_0 (Where "_" represents a space) - allow this stage to complete
3). Insert the ribbon and lock the printhead down.
4). Send the command !CSA_1 (Where "_" represents a space) - allow the calibration to complete.
This has works for me 99% of the time where the sensor array is faulty.
Dec 19, 2007 | Zebra P330i Thermal Card Printer
Zebra P330i Thermal Card Printer Logo
174 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
