Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My belkin router wont light up? - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
  • jenibod Nov 10, 2008
    my belkin router has suddenly stopped working.it is approximately 18 months old.i leave it on always and just found it unlit and no response.please can anyone advice me.
    Scholar:
  • 132 Answers
  1. Try plugging the router to a different power outlet.
  2. Reset the router.
  3. Check the power adapter specification of your router and if you have another power adapter that has the same specification then try that power adapter to your router.
  4. If using another power adapter and your router will not power on still, it is possible that your router is faulty already.
Hope this helps!
Posted on Nov 10, 2008
I have a belkin g its makin a high pitch sounds lights wont come on and it wont connect
Mine has this problem also. Apparently this is related to the voltage circuit. If someone has the schematics or the solution please tell us.
Nov 17, 2012 | Belkin F5D7234-4 Router
When i connected my belkin n150 it wont connect to the internet the modem light flashes amber ,It says connected on my laptop but the modem light wont stay green
Your Router Should Be Configured for your Internet Service Provider. To do that you have to contact your Belkin technical support & they will give you a hand. Or Please update some Details about your Internet connection who is your Internet Service Provider. What type of Internet Connection are you using is it DSL or Cable. And i will walk through the Steps For you... :)
Mar 07, 2011 | Belkin (F5D7230-4) Router (587009)
My belkin wont connect, the light flashes orange and says no internet access. Everything is plugged in the right spot and we have rang the belkin company up. but no use. ???
reset it and then load the belkin cd before you hookup the router to the system and then when it tells you too then hook up the router,make sure to revert back to the way it was hooked up before you got the router
Feb 09, 2011 | Belkin Basic Wireless Router
Has no power
1. Check to see if there is an on/off switch on the router. If there is then turn the router on.
2. If it doesn't have a switch or you've turned it on and nothing happens then you should check your
wall outlet to make sure you have power. You can test it by plugging in a lamp or other small electrical
device.
3. If the outlet is working, check your surge protector (If you are using one.) the same way you checked
the wall outlet.
4. If the surge protector is working, then check the wiring of the router power supply. Look for any
damage like nicks or breaks in the plastic shielding. If it is damaged it will need to be replaced. These
can be purchased at electronics stores like Radio Shack. They may be available at Belkin.
5. If there is no damage you have a few choices to make:
a. Replace the power cable. This may or may not solve your problem but if it doesn't work with a new
power supply then the router itself is defective/broken.
b. Return the router for repair or replacement. If you have a valid warrenty then this is a good choice
otherwise you will have to pay for the repair/replacement.
c. Purchase a new router. If this is an older router, over 2 or 3 years old, it may be a good time to
upgrade.
Nov 22, 2010 | Belkin (F5D5231-4) Router
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
On my Belkin router the wireless light only light up when somebody is actually connected using wireless - it also flashes orange when somebody is trying to connect but failing - my router is a F5D8236uk4
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
New router as of today Belkin F5d8236-4, wont connect
You will need to configure the router manually
Tell me the name of your internet service Provider ??
Dec 31, 2009 | Belkin F5D8236-4 Router
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can't configure belkin n wireless router.
yes always best to use ethernet when you can.richardm69
Feb 03, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Router loses power.
Yes its already a dead router and needs a replacement already since the light wont even stay on when its plug in to a power supply...
Jan 15, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
91 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
