Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
Our washerdryer isn't heating the water or air for washing or drying. Could this be the thermostat or heating element? - Any ideas which? Could it be linked to filter having been blocked? Thanks
    President:
  • 1,462 Answers
It is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
SOURCE:
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Tumble dryer doesn't dry. It tumbles but there is no heat
Either your heating element went out or your thermostat (which regulates the temp).
Jan 29, 2010 | Hoover Nextra 160 HNWF 3137 Front Load...
When I use the tumble dryer it does not cool down at the end any suggestions as to what could be causing this? Regards Caroline
Yep.....the secondary switch in the timer has welded together. Better Replace the whole thing. If money is a problem......wait for the clothes to cool down before handling them.
Oct 24, 2009 | Hoover Nextra HNWF 3135 Front Load...
Machine doesn't drain HNWF3135
Check your belt in the rear of the machine, it has either slipped off, or is broken. It must go around the pulley of the drain pump in order to pump the liquid out of the washer.
Sep 25, 2009 | Hoover Nextra HNWF 3135 Front Load...
Not completing cycle
if your waste pipe is attached to the sinks waste you might find the wastepipe connection blanked off, simply unscrew and remove blank. Or your water supply maybe off.
Feb 20, 2008 | Hoover Nextra HNWF 3135 Front Load...
Hoover Ultracare 1600 - Dryer not working
Check the duct work see if it is clogged up with lint.  Everything you read tells you to clean it out, but how many of us do it?  I just had the same problem with my duet dryer and when I went under the house to check, the duct was clogged up with lint and works like a charm now.
Jan 01, 2008 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
3135 Dryer Broke
If you remove the top there is a thermal fuse on the dryer heater duct, it appears this has blown, on some versions this is resettable, you will see a small button on a thermostat, push it in if it makes a suttle clip it has reset. Regards Advisor
Nov 12, 2006 | Hoover Nextra HNWF 3135 Front Load...
Washing coming out REALLY HOT even after cool spin
This might be too easy but you have definetly check that the pipes are the right way around that connect your washer or you have not accidently connected the washer to the hot water, the 3135 only has 1 connection that shuld only have cold water put into it. This would also effect it drying capability.
Sep 25, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
558 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
