Question about Maytag PYE2300AY Electric Dryer
Maytag electric dryer stpoed working
I changed the thermostat but i can't find the themal fuse location in the dryer .
thanks
  • Anonymous Apr 13, 2009
    dryer just stopped working
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Dryer stopped working but it is getting power because the inside light is on
themal fuse if it doesn't start at all, hi limit thermostat if it will
Aug 21, 2010 | Whirlpool GEW9250P Electric Dryer
I have a Maytag Neptune Electric dryer. It won't
Try to plug something else in the same outlet, if it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers. Electric dryers should have the wiring checked at the terminal block to make sure that the connection is good, or to verify that the connection is burnt out.
If the power is there, you will have to check the door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Thanks for using fixya
Good Luck and have a nice day.
Jun 03, 2010 | Maytag Dryers
I need to know thermostat location on maytag performa dryer
The operating thermostat is located on the blower housing behind the front panel, however the thermal fuse/hi-limits are located below the top attached to the heater box. They are more often the culprit as is the element in those units.. Check the exhaust path from the lint screen out to ensure a clear 4" path the entire length, as blocked ducting will raise internal temperatures and also cause those components to fail..
Have fun, and best of luck,
Thanks,
Chuck
Feb 22, 2010 | Maytag PYE2300AY Electric Dryer
Dryer doesnt work, worked fine a few days ago, checked the circuit breaker, it's fine.
check the element, thermostats, and themal fuse if not heating...
Feb 08, 2010 | Maytag Dryers
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Wont start
On the side of the heater box is a small black thermal fuse with 2 white wires going to it. If this is open the dryer will not run.Replace it.
Dec 06, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't start, light comes on
hi thanks for the question the thermal fuse fails allot caused by poor venting yo the outside this fuse is located in the front on the air duct thanks the appliance doc
Jul 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Mar 30, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
No heat from our REX7648KQ electric dryer.
I couldnt bring up this model # Is it 22ov?full size dryer? I would recheck fuse's should be 2 one for each leg of 110v . I would check to see if you have 220v to back of dryer where the cord mounts to dryer Also some models have themal fuse on burner of dryer in back, this will keep heater from coming on... You can hook the wires together, that hook to themal fuse, being careful not to short wires and test if heater will come on
Sep 16, 2007 | Roper REX4634KQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
159 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
