Also search for fstab file shows no file, after fresh install from downloaded ubuntu 8.10 Re-installed 3 times Floppy disk working on system [Windows] System. Asus m2a-vm hdmi am2 Athlon 64 x2 4GB
Why do you need a floppy disk? Seems like a config issue when setting up ubuntu, but I would like more info to be able to help you.
Same Problem
Dec 19, 2008
-   ubuntu 8.10 does not recognize my floppy my previous version did.
-   redsands66
Nov 30, 2008
-   I installed ubuntu 8.10 and the floppy drive does not show up in Places. Therefore I can not address my floppy.
-   bsimms36
Nov 30, 2008
-   HP Compaq nx9010 Pentium 4, 512MB RAM
Ubuntu 8.10 never recognizes floppies, either automatically or by command line attempts
Puppy 4.1.1 running on the same machine will recognize floppies, however.-   weinlick
I solved the problem now, so I hope it works for you. In the /etc/modules file, I added "floppy" top the list. I think the developers just removed the module loading for floppies because so few people need them now. This change should get the floppy module to load at boot. Note that you can also use the modprobe command to accomplish the same thing, but if you want it to load automatically upon booting, modify the /etc/modules file.
Hi, did you install the server version or the desktop version?? i suggest that you opn the side of you desktop and unplug the floppy disk and plug it back again, intrepid should recognise a new plug hardware automaticaly, if that does not help follow the next step.
When your pc start, after listing your hadware, and just before it comes to the grub Ubuntu graphic logo, press the esc key, and change your kernel to the previous version, and press enter on your key board, this should reverse the kernel and pick up the hardware config.
Any problem come back to me, richardicare@googlemail.com
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM...
(More)
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM Thinkpad 600
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap....
(More)
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap. pratheep.pratheeps@wipro.com
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn...
(More)
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn steps for raid 1 but i want to do raid 0
Having a problem with Beryl on Ubuntu, I play a video no problems, but if I rotate the cube the...
(More)
Having a problem with Beryl on Ubuntu, I play a video no problems, but if I rotate the cube the video disappears or starts flickering. What can I do to fix this problem?
