Question about Ricoh Aficio CL3500N Laser Printer
Changing toner We can't figure it out.
  • julie.diruss Nov 13, 2008
    I finally figured out how to change the toner but now I am haunted by a red light that won't go away! I actually just pulled the cartridge out and put it back in. The only change from doing that was the big "poof" of black toner everwhere~!
    Could you also explain to me what the dummy cartridges are for?
    Julie
    Genius:
  • 1,605 Answers
Here is the link to Ricoh printer maintanace manual
Aficio
-CL3500N-Color-Laser-Printer.htm">http://www.generalmanual.com/Printers/Ricoh-Aficio-CL3500N-Color-Laser-Printer.htm
go to page 28 , changing the toner.
Posted on Nov 10, 2008
  • Frank
    Frank Nov 13, 2008
    the dummy is put in by the manufacture in place the real toner.
    the puff you have encounter tell me that the toner is not seated correctly, that cause the toner to leak out on to the machine.
    what you need to do is pull out the toner, very slowly, and try clean up the toner area and any other place the toner can get to. ( best suggestion- use compress air.)
    take a look at the manual, make sure all the sensor are clean. otherwise, you will get error when you turn on the printer.
    then replace with a new toner.
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
HL215ON changing toner How do I change the toner?
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
Jun 01, 2011 | Brother HL 1240 Printer
52 saccaner error
52 Scanner Error Perform the following to troubleshoot a 52 scanner error:
  1. Verify that the toner door is completely closed. If the door is not closed, the printer will not allow the laser shutter to operate and will present the error “52 Scanner Error” or “Door open or no print cartridge”.
  2. Verify that the black connecting link to the toner door hinge is properly attached. If the latch is not properly attached (Figure 1), snap the hinge in place, close the toner door, and power-cycle the unit. Figure 5: Black toner door latch c00162195.jpg
  3. Verify that the inner toner door is properly positioned. Snap the door back into place at the two inner door-locking mechanisms (Figure 2). Figure 6: Inner door locking mechanisms c00162197.jpg
  4. Verify that the door hinge and upper ring are not broken. If either are broken, the unit will need to be returned to HP or a local service provider for service using the applicable warranty, support pack, or contract option. Figure 7: Door hinge and upper ring c00162200.jpg
May 28, 2009 | HP LaserJet 3055 All-In-One Printer
Changing Dell 3000cn printer cartridge
The instructions always come with the new cartridges and also are printed on the new cartridges. You move the right hand (colored) side up to unlock. Carefully pull the cartridge up and out (you can screw up the gears if you don't put the cartridges in and out straight. Make sure you've followed the instructions that come with the new toner cartridge (removing tape, shaking), put it in the same way and move the right hand side down to lock.
Apr 07, 2009 | Dell 3000cn Color Laser Printer
I have a Canon MF4690 and when changing the toner cartridge, a small guide attached with two small springs came off and can not see how it reattaches. I think it could be the guide for 2 sided copies, but...
I have this same problem and can't figure out what to do with that weird part that has 2 small springs! The printer seems to work fine, but it must be used for SOMETHING!?
Oct 29, 2008 | Office Equipment & Supplies
Changing toner cartriges
Check to see if you have removed the shipping strip. This alows the toner to be distributed. Make sure you get the whole thing out or you will have printing problems.
Oct 27, 2008 | HP Color LaserJet 2600n Printer
HP Color Laserjet4550
clen your toner surface and check that not leakage.
if leckage then replaCE IT
BY
Mar 24, 2008 | HP Color LaserJet 4550 Printer
Changing toner
Hello Glenda
I believe I can help you as I am prepared to send the entire users manual to in a PDF format if this is ok. I specifically found the remove used toner and add new toner section but I believe you may benifit from thr entire manual. Although I am new to this "FIXYA" forum I am a 20 year veteran toner boy(lol) so I am sure I can help. Just respond to "FIXYA" with a favorable comment and let me know how you wish me to respond. I see your E-Mail address and can send it that way which seems the most effective way. Glad to help, happy New Year. P.S. even if ya dont say happy things about my I help I will gladly help, I was just hoping 4 an atta boy from them! :-) Take care.
Dec 31, 2007 | Canon imageRUNNER 400S Copier
Ricoh Aficio CL3500N Laser Printer Logo
562 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
