Question about Electrolux Vacuums
I have a electrolux 2101 carpet cleaner...I filled with solution and cant find the switch to turn it on ...looking for instructions. thank you
Press the lever at the bottom right with your foot to release the handle, then tilt the handle back at the same time - tilting the handle turns it on.
Posted on Nov 18, 2008
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
Floor scrubber
You can often find them on Ebay. Just look for Electrolux or Aerus Floor Pro brushes. You can probably also find them under Electrolux shampooer brushes.
You can purchase them from the Aerus site and they will ship to you:
Or go to and follow the directions for the dealer nearest you. If close enough you can pick them up at the store, they can deliver to your door, or they can ship if you live several miles away..
Jun 08, 2013 | Electrolux Vacuums
Need manual for aereus electrolux carpet shampooer serial number a48181s bc2...model numbe 2101. we are tryingto put it back together after I took it apart to replace orings-now we cannot install the on...
As you may know Aerus does have a website where they do post manuals for some more current models. See here:
However you will not fnd the manual for the 2101 posted here or readilly available on any other online reosurce site.
I have been in contact with Aerus Electrolux by email and have been advised to call 1-800-243-9078 regarding this. Please give this number a try and hopefully their Customer Service Representaive will be able to provide the manual you require.
Thank you for using FixYa!
Nov 23, 2011 | Electrolux Vacuums
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an Electrolux Oxygen 3 Ultra Canister Model No Rel7020. I am having problems with the On/Off Button and the Bare floor/Carpet Brushroll On/off button. The Carpet On/Off will not work at all. In...
You have a problem with the electrical switches. If you are comfortable with this, take apart and double check internal wiring to make sure nothing was frayed, or disconnected. Make sure it is unplugged. If you know how to operate a multimeter, you can use it to check continuity in each switch.
Jan 27, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
Apr 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum cleaner
I think this is not the place to ask this question
Jan 14, 2008 | Vacuums
Vacuums Logo
470 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
