Question about Dell E193FP 19" Flat Panel LCD Monitor
Dell e193FPc monitor
Turns on for a second and then screen goes black but power button stays lite
  • 3 more comments
  • Anonymous Dec 16, 2008
    same to me
  • cotxmd Dec 24, 2008
    I have the same issue.  It stays on just for a second and go black.
    I had to replace the monitor, but still want to fix it, if possible.  The LCD itself has no flaw so hopefully there should be a way to re-use it.
  • Anonymous Jan 06, 2009
    i have two of these that are showing the same issues. i would love it if there was a fix. on another forum a shop said the mainboard needed to be replaced.
  • Anonymous Jan 31, 2009
    after 1 or 2 seconds Monitor screen goes black when power os on
  • brian killebrew Nov 25, 2012
    i have the same problem goes on then turns blank or black turn off then on comes on then out
The backlight or inverter may be bad. With the monitor on and the room dark, hold a flashlight very close and shine it on the screen . If you can see the normal display the monitor is OK but the backlight or the inverter which provides proper voltage to the backlight has gone bad.
Posted on Jun 26, 2010
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Screen keeps turning on and off. it will turn on then go all black but the green power button will remain green
You can inspect the power supply section first for bad caps with bulging top, or buy new PCB: http://www.lcdrepair.us/e193fpc-inverter-power.html
Make sure it matches what you have inside your monitors.
Mar 06, 2010 | Dell E193FP 19" LCD Monitor
LCD display failure
First place to check will be the power supply section, look for bad caps with bulging top first, post back what you see so we can guide you more, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Inverter/pwr: http://www.lcdrepair.us/e193fpc-inverter-power.html
Feb 17, 2010 | Relisys RLT1720 17" LCD Monitor
E193FPC : Monitor power light on, Monitor starts up and displays image for 1 second or less, goes black and stays black, If turned off and back on it will again display image and revert to black. Results...
here is a similar dell monitor with the exact same problem....
http://www.motherboardpoint.com/dell-e172fpb-monitor-t55620.html
read all the way to the bottom of the thread and you will find:
volto user_offline.gif Junior Member Join Date: Oct 2007 Posts: 1
10-30-2007, 07:54 PM I have the same monitor and it had the same problem, I got it for $10 at a garage sale because they "didnt know if it worked or not" BS, they knew it was broke. But i accepted the challenge. There are four transistors on the power supply board detailed as Q759, Q760, Q739 and Q740. It is usually just two that go bad on these monitors, but instead of hassling with testing all four, I would recommend just replacing all four. Here are some replacement part numbers. I used NTE2524, same as NTE2525, and paid about $1.25 each.
and here are Sanyo parts (hard to obtain):
2sc5707 C5707
2sd1803
2sd1804
ECG2524
The transistors are rated at 60v 20w.
Just wanted to share my success story. Hope this info helps someone. I found my info on some other forums that i can't find right now.
Nov 06, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell Computer Monitor - Black Screen
If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
Please vote if this helps.
nLinked
Computer Support Services
Jun 08, 2009 | Dell E193FP 19" LCD Monitor
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
580 people viewed this question
Alun Cox
