Question about Hitachi Televison & Video
Low color spot on screen
It's a bluish spot about the size of a dinner plate. Shows mainly on a dark background.
  • 1 more comment
  • p.yoder Nov 11, 2008
    It's a faded color spot. Shows blue on a dark background and yellow on a light background. Kind of a U shape.
    How can I get this fixed?
    Nice to have way to get answers. Does my fee cover anymore quetions I might have or is it just for each new question?
    Genius:
  • 1,550 Answers
I think you need to replace optical block .
Posted on Nov 11, 2008
    Brigadier General:
  • 6,966 Answers
In some versions/models, this could just be a dirty/dusty lens/tube. Perhaps it may be more clear if you could post back the brand and model number or better still the chassis number.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
    Sergeant:
    Novelist:
  • 196 Answers
Its the problem of the ics on the main board.either the ic is loose or getting faulty.as it will increase further.you can check out the board and do the replacement if needed.
  • 1 more comment
  • mmechanics Nov 11, 2008
    The main problem behind these color spots on your TV is the speakers you have sitting next to it. Any stereo speakers should be at least 14 inches from the television and any surge protectors should also be hidden from the TV for it also causes the same effects. But don't go buy a new TV, there's an easy way to fix this.
    Step2If you notice a color spot as soon as you set a speaker next to your television, carefully pull it away in the exact same motion and degree. Sometimes doing this still leaves the color spot but it will lesson it. The same things can happen to your computer monitor; thankfully they make the computer speakers unable to damage the monitor and if they do there is a degauss button in the monitors menu that rids it for you. Some people, like those who work in offices like to hang pictures on the sides of there computer towers (CPU), using magnets. If your having huge unfixable problems with your computer its because of these magnets. Magnets like to eat the information and software right out of your computer; first contact is always permanent damage.
    Step3That color spot on your TV screen can me removed by putting the opposite polarity of the magnet back up against your TV; opposite of with the polarity when it was damaged. Be sure to does this in the spot were it happened originally on the side of the TV (not in front) or it will cause more color spots.
    Step4Don't have a magnet but have a small battery charged drill? Switch the drill to drive (if on right side of TV) & reverse (if on left side) then place it next to the damage on the screen and start drilling. As you drill pull it straight away and repeat as necessary.
    Then the color spot is probably from magnetization.
    The screen must be degaussed either by its own built-in degaussing coil or at a shop where they have an external degaussing coil.  The charge for doing it is nominal.
    BUT: If the degaussing coil in the set is working normally the spot will dissapear over time. Each time the set is turned on the degaussing coil is activated.  You can accelerate the removal of the spot by repeatedly turning the set ON and OFF. The set must remain ON for one or two minutes each time while the coil produces its degaussing field.
    Let me know if you need more.
    feel free for further queries on this issue.
    thanks for the appreciation.
    thanks
  • Hitachi Master
  • 19,396 Answers
This can be caused by a bad coloer wheel , a problem in the light tunnel, or a polarization prtoblem if it is a rear projection LCD model.
  • 1 more comment
  • Ginko
    Ginko Nov 11, 2008
    Leave the set unplugged for 24 hours. If when you turn TV on the spot is not there , and comes back after a while, then it is the anti-polarizing screen.
    If the spot is static and it is always there, then it can be a problem with the display.
    If the spot is like a round shadow right at the center of the display, then it can be the color wheel.
    A detached mirror inside the light tunnel can also cause a similar shadow.
    It will be useful getting the model number to know if this can also be an LCD fault, in case the TV is rear projection LCD.
  • Ginko
    Ginko Nov 11, 2008
    Sounds like a defective color wheel.
    Shadows from problems in the light tunnel do not change colors, and polarization spots change in shape and size.
    The technician should access to the color wheel, located behind the lamp, inspect it and eventually replace it.
    A good idea could be calling the phone number listed on the owner manual and ask the cost for a warranty extension, that will cover the repair in full.
    I also report my previous comment for better clarity:
  • Ginko
    Ginko Nov 11, 2008
    Use this Mail
    Inquiry Form
    to contact hitachi.
    Ask them the cost of an eventual repair, or better of a warranty extension.
My vizio 32in. tv. year 2007 has a dark faint cloudy spot. whats the cause and how to fix
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 25, 2016 | Vizio Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
Bluish screen whites really bright background really dark it was fine untill some one messed with the color
Their is a CRT fluid that keeps the three lenses cool ontop of the tubes. The fluid goes bad after a few years and causes what you describe.
Read this.. http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 25, 2011 | Philips 60PP9202 60" Rear Projection...
Dark run looking spot of screen
Probably a bad backlight tube. It would look like a darkish about 1" (2.5cm) wide streak running near to horizontal part or all the way across screen.
May 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
What happened to the screen?
It sounds like you've cracked the LCD display. These can be repaired, but it might cost too much to be economical. See if your local Jessops can give you a quote so you know what's what.
All the best, Typodave.
Jun 22, 2009 | Polaroid I533P Digital Camera
Flickering red spots
its due to overheating of any component on the main board and needs to checked with a meter to locate the faulty and replace.
Jan 05, 2009 | Televison & Video
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Off color spot on screen.
Sounds like the "purity" is off on your tv. This is caused by the
picture tube getting magnetized by a stereo speaker sitting too
close or by another object with a magnet. If there is nothing
magnetic near the set you may have to have the set demagnetized. A local TV shop should be able to do this for
you on a Carry-In basis while you wait, at a minimum price, but
call for an appointment first. This fix is for a direct view type set
only (using glass picture tube). Does not include LCD or Plasma
units.
CaseyBee
Mar 24, 2008 | Emerson EWF2004 20" TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
