Question about Video Game Consoles & Games
No Audio whenever i connect my earphones to my psp. there was no audio. is there a setting for it?i've tried restoring my whole psp settings and still no audio. please help me. tnx
  • yummy_pao Nov 15, 2008
    the psp speaker is working, but when i connect any headset, no audio
  • yummy_pao Nov 17, 2008
    I've tried all kings of headset, earphones, pc speakers. Still not working. Is there any solution?
  • 50 Answers
Ear phone may be faulty..... Can you hear the sound from the speakers of PSP when you play music/games/Video
Posted on Nov 14, 2008
  • PSP GURU
    PSP GURU Nov 16, 2008
    Its 100% Headset Faulty
  • PSP GURU
    PSP GURU Nov 17, 2008
    Show it to the Authorized service centre .... As may be its a connector problem
A model TC-P42x60 and I need to use earphones. I have tried the audio outlets using a rca cord with a 3.5mm plugged into a set of earphones, that does not work.
There are no audio outs on your TV The digital audio out is an optical output meant for a sound bar or a stereo audio amplifier that has an optical input. If you have a compatible stereo system you can use an optic cable to connect the two and then use the headphone jack on the stereo system.
Aug 05, 2017 | RCA Audio Players & Recorders
Audio output
Refer to your user manual sound output type settings
Feb 14, 2016 | Hisense Televison & Video
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
Wespro mini laptop audio problem solve
Check on the earphone output socket for audio , if absent then there is no output from the system. If can be due to faulty player, faulty audio driver within the PC. If you can RESTORE the PC to an earlier set restore point it will help to retain the drivers. If not download the drives to the PC motherboard and install/run. If there is no result there is fault in the mother board- audio section.
Sep 17, 2011 | Computers & Internet
My mic does not work on my microsoft lx-1000 head set, the audio works through the earpiece but no the mic, i've gone to set up a mic in the windows 7 settings but it does not hear me. I had a...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Jul 30, 2011 | Computers & Internet
My computer lg has not coming sound
Possible fault in the drivers or the software- OS. So please try and restore the PC to an earlier set date. Open control panel , open back up /restore and try to set to the set restore point.
Also make sure that the audio settings are correct , the properties can be opened and status of drivers checked.
Check also with an external earphone to confirm.
If none of these works the fault can be a hardware fault on the audio section or a possible OS fault.
Feb 07, 2011 | LG Computers & Internet
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
Audio problem in head phines
YOUR PROBLEM IS NORMAL. PLS. CLEAN THE CONNECTION POINT BETWEEN YOUR EARPHONE AND YOUR PHONE. IT MUST BE RUSTED SO CLEAN IT PROPERLY WITH A POINTED PIN AND RETRY TO USE YOUR EARPHONE(HANDSFREE)
IF THE PROBLEM IS STILL EXISTS. THE WIRE OF YOUR HANDSFREE'S WIRE MUST BE DAMAGED BY USING IT UNPROPERLY. SO IN THIS SITUATION YOU NEED TO CHANGE YOUR HANDSFREE WITH A NEW ONE. THIS WILL SOLVE YOUR PROBLEM
REGARDS
KETAN PATEL
Feb 04, 2009 | Sony Ericsson Walkman W810i Cellular Phone
What is a' line in'connection
The line in jack is for an audio "input" from another device say a tape recorder or say audio from maybe a short wave radio type of device.
This is strictly for feeding a audio signal into this device. To feed maybe audio "from this" AZ102 C you would then use the "line out" jack.
Hope this helps.
Dennis
Aug 19, 2017 | Philips ACCESSORIES & S60202 Earbud/Line...
HELP ME PLEASE-STEREO PROB.-
I'm assuming that these are not the usualy 1/8 inch jack earphones... are these usb earphones? if so (if using xp) check the settings in the control panel/sound and audio devices/audio tab...then in the "sound playback" section, see if the headphones are given as an option...if so select them and hit okay. Make sure that there are no audio applications open when switching. Hope this helps.
Mar 29, 2008 | Audio Players & Recorders
Video Game Consoles & Games Logo
102 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
