They say i have a CPU problem either to slow or using too much or just causing a slow computer
  • Dave DeGain
    Dave DeGain May 11, 2010
    Who are "they" and what are the specs of your computer? Is it a P4, celeron, Mac, and how much RAM do you have and how fast is it supposed to be?
    Nobody can help you if you do not give even the smallest amount of information to go with. We can not just guess at what you have. You must tell us.
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Posted on Jul 11, 2011
    Problem Solver:
  • 16 Answers
Well lujm, i have to agreed with tech48, you need to give the specs of your pc. We need to know what type of proccessor, how much ram, how big is the hard disk space etc. The more info you can give, the better 'cause we are not there/infront of your pc.
Roughly, maybe your pc has been infected or your system has been corrupted. If this is the problem, the easiest way is to reformat it.
Posted on Nov 11, 2008
My computer is running slow
if it never used to run slow, and now does, then very high chance you have virus. run full virus scans, preferably 'online' , not using your installed antivirus scanner. if this fails to relieve the problem, restart into 'safe mode', and if problem does not persist anymore, it is most likely a driver issue. must uninstall devices from device manager, restart and see if problem is gone. if not, after uninstalling all major things , then use msconfig for 'diagnostic startup', if problem is resolved, figure out which one of the startups is causing it
Dec 09, 2013 | HP Computers & Internet
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
I get a norton warning that I have high cpu usage yet Im not running any programs.My computer is running slow and doing alot of clicking noises.I have 98% available free space on my hard drive and i...
1. Try disabling some of the Startup Programs.Press the "Windows" key on your keyboard and the "R" key at the same time. When the run dialog box comes up, type "msconfig" then press OK. The System Configuration Utility will open. Go to "Startup" tab, disable all startup programs, hit OK then restart computer.
2. Test if the computer still runs slow, if it doesn't try repeating the step 1, and re-enable the startup programs one by one or you can just check on the programs that you want to automatically start whenever you start Windows. These startup programs eats your computer resources which should have been used by the computer for processing instead.
3. If you hear clicking noises from the computer it might be the computer's Hard Drive. Download and run a Hard Disk test. You can download Hard Drive Utilities from here - click this link
4. If the Hard Drive test fails then we will need to replace the Hard drive. If it passes run a full system scan using your Security software. The computer might be infected by a virus/malware which causes slow performance.
Hope this helps.
Mar 21, 2011 | Computers & Internet
THE TASKMANAGER'S PERFORMANCE SHOWS 100% USAGE EVEN WHEN THE COMPUTER IS NOT PERFORMING ANY TASK.SPEED OF THE COMPUTER HAS BECOME VERY SLOW.
Start by identifying the processes which are using the cpu and stop them or disable the processes which are causing the usage.
Mar 07, 2011 | Computers & Internet
Cpu running slow, even causing audio to chatter.
Yes it may affect your speed so whenever you sit on your pc just clean temporary file
  • start
  • run
  • type %temp%
  • tap enter and delete all the files
by this the speed can be improved
May 14, 2010 | Computers & Internet
Why does my fan seem to be cycling at all times which is slowing down the computer big time
your fan has nothing to do with your computer slowing down.
your fan goes on when a threshold is reach in the cpu temperature or another component's temperature being cooled. the question is what's is causing your cpu or your chipset to work harder than usual causing your system to seem to be sluggish??
the simple answer is malware and need for a clean up and tune up
I suggest you do the following:
1. get an air can, open the case and without touching anything and watching for ESD, dust off your system free.
2. close the case and turn your computer on
3. update your antivirus and run deep scans
4. get all critical updates for your system from windows update
5. download, spybot search and destroy, malwarebytes, superantispyware, and a square free edition, update them and run deep scans.
6. defrag your hard drive
7. to improve perforamance make sure you update or upgrade memory
good luck!
Apr 23, 2010 | Gateway 831GM PC Desktop
Computer suddenly slow!
There could be a number of things that is slowing your computer down and it depends upon what is running on the computer and in the background.
For example. Someone could have hack into your computer, assuming you are on an unsecured wireless conection. A virus program is using or accessing data on your computer. Your virus program is running a scan on the computer. If you are on the Internet and the service is slow because of the amount of traffic through your ISP's connection.
The way to monitor what is going on is to run Windows Task Manager.
Press Ctrl-Alt-Del keys together to open Windows Task Manager.
There are 5 Tabs that view various functions. The Processes and the Performance tab give you details of what is going on.
In the Performance tab if the CPU is running nearly 100% that is why your computer appears slow.
In the Application tab, this shows which programs are opened and running, the more applications that are opened can make the computer slower.
In the Processes tab this shows exactly which process is running and who or what is using that process and the CPU usage. Click on the CPU label twice and it will sort the CPU usage from the highest to the lowest. You maybe able to determine the process which is causing the problem and work out if you can shut down this process/program or it is a problem that needs to be resolved.
I suggest that if you are using a wireless connection that it should be secured to prevent unauthorized access. Install a firewall and anti-virus program. Scan the computer for viruses and trojan horse programs etc.
Aug 19, 2009 | Dell Computers & Internet
Think pad T30 - very slow to shut down
Your computer needs a clean.
Be sure that your computer is not virus or spyware infected.
Check if the fan is working, another cause could be related to a hardware issue.
Oct 09, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
