Question about HP LaserJet 3380 All-In-One Printer
My sheet feeder is broker
I ordered a new roller part but it is still broken, could you tell me where to get a drawing of how it should be assembled or someone in the Phoenix area that could repair it for me. I hate sending faxes one page at a time. Thanks
    Scholar:
  • 121 Answers
Copy paste link in your browser open
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00064666/c00064666.pdf?jumpid=reg_R1002_USEN
Open page 93-95 in this manual there is step by step guide as to how to go about solving your issue
Posted on Nov 11, 2008
Canon ImageRUNNER 330s Auto Original paper Feeder does not work when copying. Seems not to be mechanical in origin.
If the devices (Rollers etc.) are misaligned, the paper feed will shift the sheets to one side or the other. If the paper tray is not true when inserted, the paper will be grabbed incorrectly and fed on an angle. I suggest you take apart the roller assembly and lay them out on a table. Look them over for defects. If any bits of paper are left in corners, etc., remove any debris. Wipe down the rubber rollers with rubbing alcohol and air dry. Make certain the rubber parts are NOT slick. Slick rollers will also mess up the paper intake or track movement along the way. I rub all rubber rollers with an very fine abrasive paper to remove the slickness, but I am careful not to damage them. Put the parts back in order. Check the alignment and do not FORCE parts when inserting them. All components should drop in easily and positively.
Feb 04, 2018 | Canon Office Equipment & Supplies
Samsung ML 1430
http://degenportnoy.blogspot.com/2006/10/samsung-ml-1430-wont-feed-paper.html
Dec 10, 2007 | Samsung ML 1430 Laser Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Top paper feeder roller rotates but does not draw in the paper
There is no replacement rollers available so, printer needs to be replaced.
Apr 08, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Canon printer #346 error is showing
346 says the timing is off for the feeder and the purge unit, usually a broken gear on the sheet feed assembly. A new feeder will run around $50.00 plus labor.
Sep 02, 2009 | Office Equipment & Supplies
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
Scanner Sheet Feeder Malfunction
Change the top pick up roller. Can be ordered through the Dell parts dept. takes about 30 seconds to change.
May 23, 2008 | Dell 1600n All-In-One Laser Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Pixma iP4200
These problems cane be caused by a number of things.
1. Dirty or worn pickup rollers. Clean the rollers with alcohol. This can be hard to do because you have to clean the portion of the roller that actually contacts the paper. This will only work if the rollers are slipping on the paper.
2. Object stuck in paper path. Again, can be hard to get rid of depending on how far in it is. It can actually prevent the tray from moving into the pickup position.
3. Broken gear in the paper pickup assembly, or somehow the timing has been changed. The gears in many paper pickup assemblies (or ASF for Auto Sheet Feeder) have to be timed correctly. If someone has pulled a piece of paper out causing the gears to skip a few coggs, the timing can be off and the unit will either not pick up paper or will fire a sheet or two out as soon as it's turned on. Unfortunately this fault would have to be corrected by a service tech who knows how to reset the timing correctly.
Nov 12, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP LaserJet 3380 All-In-One Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
