Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
that indicates that, the voltage is low,
but just adjust your britghtness lower, and it will clear that problem
Comments:
Apr 27, 2009
- take your tv to w/shop, they check on the power supply, i had a similar problem, the voltage is low at the output.
if you want to proov reduce your brightness and that will finish.
i have a sony tv it was working fine till last night when turned on the tv picture started to skew...
(More)
i have a sony tv it was working fine till last night when turned on the tv picture started to skew upwards and then went black the sound is fine
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting...
(More)
I have just moved my satellite receiver and DVD recorder to a new cabinet and upon reconnecting everything, I can no longer access the DVD recorder using the TV/VIDEO button on my Sony KV-32S42. The TV recognizes the satellite receiver as Video 1 but I get only snow when I select VIDEO. How can I set the DVD recorder as a 2nd input to the tv. All connection are as specified in the TV and recorder manuals.
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will...
(More)
recently purchased a kv-32s42 32" at an auction. Tv was working but when we got it home will not turn on. no lights no sound. Any ideas?
