Question about Casio Exilim EX-S2 Digital Camera
Exilim camera, PNY optima SDHC memory card error
Okay so i have the PNY optima SDhc 4gb memory card and an exilim camera. theyre both new.
i got the memory card and put it in the camera, formatted it and it worked. so i took about 40 pictures and they all showed up fine. then i put the memory card into my hp1300 printer and it says "error found on card" so then i got the usb cord for my camera and hook it up through there and all of the pictures show up just fine.
this was the first time.
so we thought the card was just having problems, so we took it back and exchanged it for a new one. but before i got to put it in, i dropped my camera and the lense broke. so we took it back and got a whole new, but same, camera.
so its the same exact camera and the same exact card and theyre both new. so then i formatted the card, and took about 10 pictures, i tried to hook it up to the printer again and its doing it all over again. the pictures will show up on my camera but they wont show up on my printer.
please help!
    Genius:
  • 1,234 Answers
Hi
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 29, 2010
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Nov 26, 2011 | PNY Attach? 16GB USB 2.0 Flash Drive
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
Whenever i insert the 4 GB SDHC memory card into my Exilim casino digital camera(12.1 mega pixels), nothing appears on the screen and it wont work. Why? It wasn't like this before :/
First, check try the card in another device, does it work, if no, the card has possibly failed, if yes check your user guide, make sure this camera can accommodate a 4gb SDHC card, if yes, check 2/3s up the left hand side of the card, is there a sliding notch offering a choice of lock and open, unlock the card.
Apr 08, 2011 | Casio Exilim EX-S600 Digital Camera
I have an Exilim EX Z500 digital cam, the recent Micro SD that inserted to it have only 256MB that's too short.. so I bought a 4GB Micro SD card.. but why can't my EX Z500 accept a 4GB?
The problem is that your camera will only read SD cards, not SDHC cards, I checked its specification. You found your 256Mb card too small and bought a replacement, not noticing that it was SDHC. The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. I'm willing to bet that the 4Gb card you got is actually SDHC because 4Gb SD cards are so rare that I've even seen a guru on this site claim they don't exist. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it.
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 21, 2011 | Casio Exilim EX-Z500 Digital Camera
I have a casio exilim exz280 and i can't find what kind of memory card compatability it has anywhere. my main question is, will it support a SDHC 16gb card?
The manual does not specify a maximum size but says it does support an SDHC card. The smallest SDHC card is 4GB which is enough for 29 minutes of video recording. Therefore 8GB would seem adequate, although there seems no reason why 16GB should not be supported.
You can downloaded the manual free, here:-
http://shop.retrevo.com/m/dailydeal/index?status=http%3A%2F%2Fwww.retrevo.com%2Fd%2Fds%2Fprogress%3Fdoc%3D5b2a0ec6af6b4da31b470c1716bf757a%26rk%3D0.7228483972243592
Jan 15, 2011 | Casio Exilim EXZ280 12MP Digital Camera
How to solve card error when i put in an 4 gb sd card on my casio exilim ex-s600
There are no 4GB SD cards. Any card that size is actually a SDHC (High Capacity) card. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 05, 2010 | Cameras
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
I have this my pny optima sdhc 4gb and it freezes my pc when I want to get the pictures off or the videos. Works fine if I use my usb cord to the camera, but I want to know why it wont work just from the...
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
May 07, 2010 | PNY 4GB Secure Digital High Capacity...
SD card
It seems that you are using an SDHC (Secure Digital High Capacity) card. It's incompatible with certain older models of cameras. I think the most you can put in your camera is 2GB. I've done some research and it doesn't say anything about your camera being SDHC compatible. Return the card, get a 2GB.
Jan 14, 2009 | Casio Exilim Pro EX-P600 Digital Camera
Casio Exilim EX-S2 Digital Camera Logo
201 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
