Question about Williams 1403622 Gas Compact Heater
Pilot wont' stay lit
Williams model #3056512.0 Serial #27051240. Natural gas heaters.
  • Williams Master
  • 3,162 Answers
Try clean pilot ..... replace thermocouple on heater
Posted on Dec 30, 2009
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
I have a williams wall heater in the garage model #3003612 the pilot wont stay lit what shall i do?
shut off gas use compressed air blow into and around over any tube. retry the pilot
Nov 01, 2015 | Williams Heating & Cooling
We just purchased a Williams 1403622 natural gas heater and installed it yesterday. However, the pilot light WILL NOT light. Can you help?
If you mean that the pilot light does not stay lit, you could have a bad thermocouple or a loose connection at the gas valve. Make sure the flame is against the thermocouple. If you mean that the pilot won't light at all, bleed out the gas line a bit more.
Mar 07, 2011 | Williams 1403622 Gas Compact Heater
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
The pilot light will not stay lit, I was told
Hi, this heater doesn't have a thermocouple, it uses a pilot generator which is more reliable so I doubt you need to change it out. First thing to check is that you have a clean "sharp" blue pilot, you should be able to hear it quietly roar. If it is yellow and appears "soft", the pilot need to be cleaned. The easiest way is to use a straw or tubing of some sort to blow into the pilot, gently tapping the pilot assembly. That should clean it up and heat the pilot generator properly. Tighten the the screw terminals at the control valve to assure good electrical connections and last but not least turn off the thermostat until you get a standing pilot. Good luck and stay warm.
Jan 13, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Pilot flickers replkaced ther-cup now pilot wont lite/stay lit.
Blow out the dust from the pilot and reposition the pilot where the flame hits the tip. more
Jan 26, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Williams 1403622 Gas Compact Heater Logo
195 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
