Question about Sony CDX-T69 6-Disc CD Changer
Problem with stuck magazine....
I have a stuck magazine inside the cd changer and I know that there is a disc selected but my head unit just says "cd check".When I press the grey eject button the head unit just says "no cd" and then it seems that it fails to recognize the changer at all from then on. This all started happening after my battery went flat and I had to restart the engine using jump leads. Is there a manual way of getting the magazine out or can anyone help? Thanks.
  • 1 more comment
  • Bocban Mar 27, 2008
    I have a similar problem.
    Left my lights on and the battery died.
    I got the car restarted using jump leads but now I have two problems.
    First, the CD changer will not "grab" the mag with the 6 CD's. I push it in but nothing happens.
    Secondly, my wipers now have a mind of their own, regardless of which position the stalk is in the wipers will wipe for about 6 or 7 times and the stop anywhere on the windscreen.
    Is my BSI buggered?
    CAR: Peugeot 406 HDI 12/1999 2L
  • bosimasan May 03, 2008
    Hi, I have a Toyota Celsior with a Pioneer cd changer in the boot it has a cartridge in it but when you press the button on the changer the door will not open.
    Any help would be appreciated.
    Thanks.
  • comfortables Jan 07, 2009
    listener85 you are a star.
    same prob, battery died on my honda stream from then on no changer control from head unit, changer had power but no function and the eject stopped working.
    following your instructions had it fixed and back in the car in half an hour. anyone else reading this it looks technical but was really straightforward. I can stop looking on ebay for a replacement now.
    well happy, cheers
OK I have had exactly the same problem and spent the last hour or so fixing it. It seems to have its logical knickers in a twist after the battery going flat and won't eject because its left a CD in the playing position, IE, out of the magazine. So, remove the changer from the car (usually velcro then pull off the two phono and the power connectors) and undo the four small cross head screws holding the case on. Pull the front panel off (you may need to pinch the case in the middle top and/or bottom as there is a clip here holding the front panel), then either pull the sides of the case out until the two rotary Horizontal/vertical mount controls disengage (or you may be able to rotate them anti-clockwise until they pop off, but I didn't try this) and lift off the lid. Next, pull the four little mounting posts on the internal deck assembly out of their four rubber mounts on the outer case, and disengage the two springs from the horizontal/vertical mounting controls. The mech is now loose inside the case but be careful as its attached by a rather delicate ribbon cable to the outside cables and connectors, This will unplug after you pull off the sticky tape holding it to the chassis, but you might be able to do the rest of this without unplugging it if you turn the mech over carefully. You will see a motor assembly and several white cogs (actually you will see two but the little tiny one with a worm (spiral) drive only moved the CD mech optical head so ignore that one). Using a small screwdriver, carefully rotate the cog closest to the motor so that (viewed with the motor closest to you and to the right) the plastic parts under this assembly start to slide to the right. You should actually be able to see the CD underneath start to move to the laft, back into the magazine, and the CD mech will open up to release it. Once the cog doesnt want to turn any further (and the CD is completely back in the Mag), then you will be able to manually eject the mag by pulling sideways gently on a round white part on the mag side. The mechanism should click and release the mag. Hey presto... fixed. Now just reassemble the whole thing back into its case, probably a good idea to check that each of the CD's is correctly seated in the mag and that there is nothing wrong with any of them that could cause it to jam again, then go try it in the car prior to final assembly. As we now know that this unit seems to be prone to throw a wobbly if its power is removed with a CD in it, I would strongly recommend that you eject the mag before disconnecting the unit for final assembly, assuming it all works OK now, or indeed any time you might have to disconnect the car battery for any other reason. Hope this helps, it did it for me! Mark
Posted on Jan 21, 2007
I have used what Listener85 posted and the advice was spot on.The rubber mounts were tricky getting back on but persistance payed off. Thanks a mil, u saved me £100!!! Dan, Cambridge, Uk
Posted on Mar 20, 2007
I had the same problem, and using the above method I managed to eject the magazine. After re-assembly a black metal strip has come loose but I have no idea where to attach the other end. Please see photos. Can someone please tell me where it goes? I can pipe it to the underside but there is no logical place for it. http://homepage.ntlworld.com/kevin.keung/Tmp/t69ii.JPG http://homepage.ntlworld.com/kevin.keung/Tmp/t69i.JPG The head unit still does not recognised the changer.
Posted on Jan 29, 2007
    New Friend:
Excellent post Mark. Worked wonders for me. Many many thanks.
Posted on Jun 18, 2015
    New Friend:
No the procedure does not work with me.
The CD is still being held by the mechanism and will therefor not move at all.
Posted on Jan 02, 2015
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Magazine is stuck inside the ch3083 cd changer. How can I get my 8 disc magazine out of the player?
you have to pull the 4 retaining screws and remove the cartridge manual if it gets stuck
Aug 23, 2009 | Eclipse CH3083 8-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Clarion arx9270 error
Typically means the CD is stuck, has a reading error, or the magazine is stuck. If jammed, you'll have to clear the stuck CD which may require disassembly. Try removing power and rebooting.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jun 18, 2017 | Clarion ARX9270
CDAC ER2
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
hope this helps,
trin
Nov 17, 2007 | Clarion DC625 6-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
Sony CDX-T69 6-Disc CD Changer Logo
2,804 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
