Question about Thermador SC272T Electric Double Oven
F7 trouble code
Power went out on my SC272TS double oven. Now I have an F7 trouble code on screen and the unit is beeping. I have turned power off at ckt brkr, waited for about 5 mins and then cut back on. F1 comes up first, then F7 and it stays on. What can I do to further troubleshoot before calling in tech support?
  • Anonymous Nov 15, 2008
    f 54 and beeping, what to do ?
  • Anonymous Jan 01, 2009
    same problem
  • 623 Answers
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Posted on Nov 10, 2008
Wall ovens
This Usually indicates a shorted keypad. Turn off at the breaker. Unplug membrane strip connected to the clock from the clock, turn breaker on. If code comes back replace the clock, if no code you need the touchpad replaced
Let me know how this goes, thanks
May 11, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
I have a sears wall oven model 911 30469893 and during cooking it kept displaying set but no buttons would work, I pressed clear to cancel and was going to press set and start again and no I have a code F7...
Sorry to read about your problem, I hope this helps you out.
you code f7 means keyboard issues.. try to turn off power to unit at ckt breaker, and see if problem clears..
if not you need to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Ovens
My oven is beeping and the F1 code and F7 code are appearing on the screen
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Can't clear Code F7
For a temporary solution, put a magnet over the "clear off" button. I used just an ordinary refrigerator magnet and it stayed off
Oct 03, 2008 | GE Profile JTP56 Electric Double Oven
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
F7 alarm
F7 stands for a faulty touch pad, faulty clock or both. Usually it's the touch pad. Most manufacturers recommend replacing both of the components. First, because they make more money that way, and second, it's the easiest (although more expensive) way to fix this problem. If you'd rather try and save some $$$, you can perform the following test and hopefully identify which of the two components needs to be replaced. The test... Disconnect the power to the oven before performing any repairs. Something triggers the clock to display F7 error code. You can unplug the touch pad from the clock and see if F7 comes back on. If it does, the clock is bad. If it does not, the touch pad is bad. Hope this helps, APP tech
Aug 04, 2006 | DCS WOSD-230SS Stainless Steel Electric...
Thermador SC272T Electric Double Oven Logo
1,360 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
