It commonly has a PF indicator on the display (not sure if the power is going out regulary or not, it is a house I am fixing up so I dont live in it) , when you push the 1 button it comes on automatically, but you cant cancel it. The start and cancel buttons dont work at all. Plus I can't even set the clock. Whats up?
SOURCE: Westinghouse WST3501 Microwave
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the
cooktop can damage the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
SOURCE: Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
SOURCE: Hi. I pressed the 'quickstart'
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
SOURCE: My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
To Turn the Control Lockout Feature On or Off:Process B
- Make sure the microwave oven and timer are off.
- Press and hold the CANCEL keypad for 3 seconds.
- 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
- Repeat to unlock. Again, 2 tones will sound.
Hope this helps?
- Press and hold the START keypad for 5 seconds.
- 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
