Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Thin Twin Fills up with water and then Hums!!!!!! Dryer works fi
Is it the motor, a broken belt?
  • 640 Answers
This unit has no belt,,your motor coupling broke,,i can walk you though,,post question how to change motor coupling,,and its not your motor
Posted on Dec 25, 2008
Washer is not working, was drying clothes and when I check them I noticed washer was full of water, drained water and washer not working.
sounds like lid switch problemes, just bypass it to test, if you ear the motor running and it doesnt turn then it should be the coupling between the motor and transmission thats broken, good luck, Alain
Jul 12, 2015 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Oct 28, 2012 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
My thin twin dryer goes on but does not spin
your dryer has a belt! if you hear the motor going thats good.you will have to investagate further.the belt goes around the drum thru an idler pully then on to the motor
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer fills up, motor hums, but no spin.
sounds like the drive belt is broken these models have pump belt and a drive belt
Oct 16, 2008 | Maytag LAT2300 Top Load Washer
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
219 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
