Question about Jenn-Air JED8230 Electric Cooktop
Have cooktop JED 8230 ADS Jennair-would like to replace grill
Would like to replace grill with a griddle or if not available a second cooking element, radiant (solid) cartridge, would like to get price, may want to replace left halogen element as well.
Hope you will be able to give me advice, have not been able to get through to anybody so far!
Thank you, Elda Soder - eldas@shaw.ca
3 Suggested Answers
  • 1894 Answers
SOURCE: clickin noise and no heat on JED 8230
clicking nosie is due to problem in ur power board.
please look at the relays
Posted on Jun 18, 2008
heatman101
  • 43501 Answers
SOURCE: I have a Jenn Air JED 8230 cooktop with a bad heating element
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
heatman101
Jun 28, 2010 | Jenn-Air JED8230 Electric Cooktop
Clickin noise and no heat on JED 8230
Jun 18, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
240 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
