Question about Hitachi 50GX49B 50" Rear Projection Television
No Picture, Raster or Sound
PROBLEM DESCRIPTION: Believe the problem is in the power suppy. Model: Hitachi CU 5002k 50" 3 tube projection. No picture, raster or sound. In a dark room there is no lights or filiment glow. Unfortunately no burned out parts, smoke or sparks either. I have no scope. Have VTOM. Output from the Sub Power Supply is, and should be, 122 VAC (Point AD). Imput to the Power Deflection Circuit (Point AD) 122 VAC. Then goes to a Diode/Capacitor Bridge Circuit and emerges at a fuse at 76 VDC. It then goes thru two capacitors to a test point (30). At test point 30 the voltage should be 129 VDC and is 76VDC None of the diodes on heat sinks are (temperture) hot or even warm. Haven't preceeded on to the flyback transformer because it is much further down the line. SUMMARY: I suspect all the parts in the circuit. In particular the bridge rectifier and a switching transitor. I don't expect a definative answer, but would like your thinking on a solution to this problem (Am I looking in the right place?) Going to a TV repair shop with this older set (1992) is not an option and I do have limited electronic knowledge; altho this knowledge was gain on tube sets...A long time ago! Your imput would be sincerely appreciated.
    Top Expert:
  • Hitachi Master
  • 75,025 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 03, 2017
  • 163 Answers
SOURCE: tv powers on but no picture or sound
luckyly here are tech that have knowledge of electronic,if you dont whant any boddie ripp you off, well this gonna help you. Definitively, your set have a short, in the power supply or in the horizontal circuit, with this in mind request to varius tech an estimate, and what, they think is the problem, then you can take a good decision...good luck
Posted on Aug 10, 2006
SOURCE: 1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
My tv has stopped working for a week now, just turned off, have no sound or picture.
Have tried to turn off for a bit and then tried to turn back on, still the same.
there was no loud sound from tv. to think it was the bulb and the picture looked great till just went blank, and freinds say they think it's fuse. Was wondering if you you can let me know what
I can do ASAP. Thx so much.
Posted on Sep 16, 2008
  • 10594 Answers
SOURCE: Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Posted on Oct 01, 2008
  • 5138 Answers
SOURCE: REPOST: Hitachi 60SX12B Rear Projection TV typical(?) problem
If you can solder you can Fix It STK ICs they are big black ICs will have part number on them example STK392-110 replace Both and these resistors RK42 3.3ohms RK46 1.8 RK5 2.7 RK54 1.5 RK58 3.9 RK60 2.2ohms upgrade to STK392-150s better ICs
Posted on Dec 03, 2009
Testimonial: "Quick and thorough response! Thanks!"
atelier mj
  • 70 Answers
SOURCE: 52 Hitachi rear projection T.V. (model #, 53FDX01B)
look for EP98, Q655 and D756.
Posted on Apr 22, 2010
Picture and sound went out. quickflash across the screen. then nothing. tv still has power. model number 46ex2b. couldn't find it listed
the problem may be in the heater supply, there are 3 picture tubes in projection tv. remove the back cover, switch on the tv & observe the heaters are glowing inside picture tubes. if not unplug the tv wait for 2 minutes, & trace the picture tubes' heater wires. there may be dry solders in heater power supply.
Aug 25, 2011 | Hitachi Televison & Video
Signal Problem
When the sound is working and the picture is not it indicates the main power supplies are working but the picture supply is not. The picture supply that powers the projection tubes is a high voltage generator and is very expensive to repair. Not even most tv techs now how to troubleshoot them. So, I cannot recommend you repair it yourself unless you are a trained high voltage tech.
The cost of repair - my wild guess - would be around $300. However, the real cost can only be determined by someone who can make an accurate diagnosis - which will require a hands-on approach the problem.
If you have any other problem please ask me..
Please don't forget to rate me as fixya..
Feb 09, 2008 | Televison & Video
Hitachi projection tv has no picture but has sound
hi.. if your projection TV has no raster at all, it has problem with high voltage supply. there are two separate power supply inside your TV for audio and for the high voltage for 3 CRT tubes.its very dangerous to service it by yourself.
Aug 14, 2011 | Hitachi 57F500 57" Rear Projection...
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as should see an access door refer to owner book of the correct model and you can replace may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Hai i am in sony projection model fx532
Hello Anand,
                  Arrcoding to the led blinks 10 time indication here find the possible causes of this indication hope this will help you.
 The diagnostic description is
• HV protection
And possible areas and parts are as fallows.
1-• Q8014 or Q6013 have shorted replace along with R8051 on D board.
2- • IC8005 is damaged. (D board).
Nov 24, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture but noice
Its possibly a defective vertical output IC as that can cause the picture tubes to blank out and volume will audio will remain.
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
Projection tv no picture has sound no picture
Try resoldering the vertical output IC. The crts may be blanking due to vertical deflection dropping out.
Apr 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
Phillips model # 9P5034C101 Projection TV picture tube
I have a Philips 50 inch rear projection when I power up I have no sound or picture is it done or fixable?
Feb 13, 2008 | Televison & Video
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Hitachi 50GX49B 50" Rear Projection Television Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
