Makes a loud popping noise and won't print
Service error 5700. Cannon mp780 multifunction printer
  • s660146 Dec 23, 2008
    I call it a clicking sound and it won't print.
  • 685 Answers
Http://damnprinter.com/226/canon-service-call-errors.html this site will tell you a couple things you need to know it says a sensor error
Posted on Nov 10, 2008
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Canon Wrong Cartridge
May i know if you use an original ink for your printer..?
May 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error msg with picture of cup
What a RIPOFF This Cannon Printer was !!!
Apparently there is a ripoff feature in this printer that after a certain number of prints an 'absorber" will fill that can only be emptied and a counter reset by an "authorized Cannon Repair Service". Good Luck Finding One that will work on a model that is the "current" one.
As I have to go out and buy a new printer today, you can be assured I will NEVER buy a Cannon one again
Jul 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wireless printing on Canon Pixma MP780 printer.
Excuse me I was wondering how i can tell if my printer has wireless capabilities? It is a: Cannon pixma mp780
Jan 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mp780
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
thats the service manual for your printer it contains detailed step by step instruction in trouble shooting and repair
Sep 07, 2007 | Canon PIXMA MP780 All-In-One InkJet...
408 people viewed this question
jasbo
jasbo
