Question about GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave Hood trips breaker and fuse when door is opened?
I have a Whirlpool Gold microwave / range hood that was manufactured in July 2006 (model: GH4184XSB-1). It was purchased new and installed (by me) in the summer of 2007. After about 6 months, it stopped working. I discovered the house breaker had been tripped. I reset the breaker, but it did not fix the trouble. I installed a new 20 amp fuse for the microwave and everything seemed ok. At the time, I assumed that my wife had cooked without using the exhaust fan and moisture shorted out the appliance. A few months later it happened again , and I repaired it as before. As the warranty expired, it began doing it more frequently until regular usage is now impossible. Specifically, the breaker trips when the door is opened (every time). And most of the time (but not always) the microwave's internal 20 amp fuse goes too. Everything else works fine. The microwave runs fine as long as we unplug it before opening the door to place food inside or to remove food after cooking. Other than this issue, the unit is like new. Is this something that a moderate handy man might be able to fix? (FYI: I understand that microwaves can be dangerous, but I'm good with instructions. I wired and plumbed my new home (two story, four bedroom and three bath) using instructional books.) Thanks.
Shawn
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 22, 2007
  • 38 Answers
SOURCE: Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Posted on Mar 20, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
  • 19 Answers
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Posted on Jan 06, 2008
SOURCE: GE JVM2070 issue
The same thing just happened to us..... there is no fuse on the microwave but we check our fuse box and tried another plug and it still did not work. GE sent us a new smartboard and now I trying to figure out how to get the thing apart.
Posted on Apr 05, 2008
Hood light & exhaust fan not working
You have no power to the unit. Breaker is out or the hot wires into the hood has come apart. The wires coming into the unit usually terminated in a junction box next to the fan housing.
Teas it for power an/or reset breaker.
Oct 21, 2013 | Whirlpool GH5184XPQ Microwave Oven
Roper microwave /hood has stop completly working model # MHE14XMG1
The magnetron can overheat if the internal cooling fan fails, when you run it empty, when you run it a long time, or when you cook low-moisture foods like popcorn, bacon, or baked potatoes.
When the magnetron overheats past a certain point, its thermal protection device will kill power to the whole unit.
If the protection device is a thermal cutout, it will need a new thermal cutout.
If the protection device is a thermostat, it should reset after the oven cools down. If not, it will need a new thermostat.
You or someone you know can check this.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. I've attached a marked excerpt.
In this model, the other parts which can commonly fail and render the oven "dead" are the 20A line fuse, and one of the cavity thermostats.
You can order parts from the Pros here. Just enter your full model number to do a lookup.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
No display, no light, no fan, microwave dead!
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
It may be the fuse, which is located in the upper area behind the control panel.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
(Don't be confused by the base or hood thermostat, which is on the floor of the chassis. It will read normally open).
The fuse and magnetron thermostat can be checked with out taking the oven down from the wall, but if you need to check the oven thermostat, you will need to pull it from the wall.
To help with that, you can download Whirlpool owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 25, 2008 | Whirlpool MH1140XMS Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Breaker blows
When you turn it on? You mean when you plug it in?
When a microwave blows a breaker but not the fuse, it's often a shorted monitor switch (usually the middle door switch) or one of the other two door switches, or a loose or broken door switch mount.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 15, 2007 | Whirlpool MH2155XP Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
GE JVM1190SY/WY/AY/BY Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
