Question about Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook
Diactivation of Windows taskmanager
My taskmanager has diactivated automatically,and i want to know how to solve it.
    Problem Solver:
  • 4 Answers
Try this. Go to your start menu and click on control panel. Next find the appearance and themes icon. Then the task bar and start menu icon. From there you should be able to choose your settings for your task bar.
Posted on Nov 11, 2008
Diactvate turn signal noise 21012 impala
what noise? click, you cannot disable the click, that is what makes it work
Feb 01, 2014 | 2012 Chevrolet Impala LS Sedan 3.6L V6 FFV...
Tip
Steps to Delete Files Used by another Program in windows
Hi,<br />Follow these steps to delete any files used by another program.<br />1. Right click the windows taskbar and open taskmanager.<br />2. Kill explorer.exe from the taskmanager.<br />3.Click file-&gt;open new task from the taskmanager window.<br />4. Type cmd.exe in the box and command window will come.<br />5. Go the directory of the file to be removed.<br />6. Delete the file using following command<br /> del fileName<br /><br />
on Jan 05, 2011 | Computers & Internet
How to solve when its hang
When a program on your PC is hanging, simply press these combinations simultaneously:
CTR ALT DEL.
If you are using XP, this should automatically open up the taskmanager. But if you are using Vista or Windows 7, it would open up some options, from which you are to choose to start the task manager.
There, you would see the list of running programs and non responsive programs.
End the programs that are not responding.
If they proove difficult to end, then go to processes, and end the proccess which the progam runs on.
Hope that Helped?
Success.
May 24, 2011 | Samsung Galaxy Tab Tablet PC
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
My computer may be a victim of software counterfeiting..the copy of windows did not pass genuine windows validation
There is actually a way to bypass the comment " your computer may be a victim of software counterfeiting..the copy of windows did not pass genuine windows validation".
try this:
1.Kill the process wgatray.exe in Windows TaskManager (Select it then right click and select End task) and restart Windows XP in safe mode. Now delete the following files:
Delete WgaTray.exe from c:\windowss\system32
Delete WgaTray.exe from c:\windows\system32\dllcache
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify.
Delete all references in your registry to WgaTray.exe (repeat search using F3 function key).
Worked for most people.Check it out...
Mar 07, 2009 | Microsoft Windows XP Professional
How can i make exe as a windows service without programming
There are some solutions for your problem, everything has
positive and negative side. (Pro and contra)
1. Startup folder
Put your exe or bat file to the startup folder. The Windows will start automatically when the Windows is starting. You put the exe to the desktop, then copy to Start/Program/Startup folder.
Positive: Quickest setup
Negative: To stop your program, you have to start the taskmanager. (taskmgr) You have to start taskmanager if you want to check the status of your exe.
2. Make a Windows service
Serveral ways can do it. The Windows resource kit contains
two utilities with this programs you can do it.
(instrsrv, srvany)
Here is the appropriate link:
http://www.tacktech.com/display.cfm?ttid=197
You can do it with registry modifications.
Here is the instructons:
http://www.overclock.net/faqs/119474-how-run-program-service.html
Positive: You can control your program from mmc
Negative: A bit complicated
I suggest to use service methotd instrsrv program.
I hope this helps, and you like it. :)
Jan 10, 2009 | Microsoft Windows Server Standard 2003 for...
Virus? Taskmanager is broken
Doesn't seem like a need to reformat just yet.And, you may not have a virus.
Have you updatd to XP SP3? You can find out by clicking the Windows key +Pause simotaneously in the subsequent popup it should be noted under "System:"
There is a way to repair your installation without reformatting.
Let me know about my above quesions and I'll be happy to get you to a Anti Virus program that scans during Boot Up and also get you started to Repair the OS.
Regards,
Worldvet
Jun 02, 2008 | Microsoft Windows XP Home Edition
Explorer problem
hi
rajkumar there is no virus in ur pc what u have to do first;reinstall
operating system (windows xp/ vista) it will definitely solve ur problem trust me
shailendra
Mar 09, 2008 | Computers & Internet
Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook Logo
112 people viewed this question
Alun Cox
