Question about HP LaserJet 3600dn Printer
Error 59.0 i have a problem with my printer it has an error code 59.0 what should i do?
    Problem Solver:
  • 5 Answers
Im haveing a search on the web but when i used to repair printers error code 59 normally meant a problem with the fuser unit
Posted on Dec 05, 2007
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
What is Error Code:59.A0 for Hp laser jet 400 M401d?
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
Jul 20, 2016 | HP LaserJet Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
59.9 Error turn off then on
1. Turn the printer off, and then turn the printer on.
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly.
4. Replace the main motor.
More Info... Hp Error Code 59 Service Repair Errors 59 Fix Codes Message And...HP Printer Support
Thanks,
Jul 10, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 10, 2011 | HP LaserJet 5550DN Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
May 15, 2009 | Office Equipment & Supplies
Error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Apr 18, 2009 | HP LaserJet 5550 Printer
Error 59
Error 59 normally refurrs to the fuser unit replace and test.
Thanks J
Nov 04, 2006 | HP LaserJet 3600dn Printer
HP LaserJet 3600dn Printer Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
