Cd drive my cd drive is working only in reading mode but it can't write
    Problem Solver:
  • 18 Answers
Helloooo!!!
A cd rom can only read,
A cdrw can read and write
please specify
Posted on Nov 12, 2008
My cd drive wont recognize the mcafee disk to clean the spyware infection on my laptop
See if your disk will read in another system. If it will, we know the disk isn't the issue.
Try reading a different disk in your system. If your system will read a different CD, we know the drive isn't defective.
If neither the CD nor the drive is defective, then this very well could be because the infection itself is causing the issue.
Try booting in safe mode (press F8 repeatedly as the operating system first starts to boot and choose safe mode) and see if the disk will read then.
If the disk still won't read, check for contaminants on the CD and the drive lens.
Feb 22, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
IN THE CD DRIVE ALL CD READING AND PLAYING EXCEPT DVD. DVD NOT READING NOR PLAYING AND PATH NOT SHOWING. BEFORE IT WAS WORKING PROPERLY. NOW ALWAYS IN THE CD WRITING MODE.
you can go on line and download an updated driver at no cost if you contact the maker of your computer on their web site
Mar 03, 2010 | Computers & Internet
My E drive is not working. how can i fix it.
Have you tried cleaning the laser assembly? If your OS still sees the drive then it may just be having trouble reading.
Try this
First try to boot from your xp cd. If it fails to boot from the cd then your drive is screwed. If it does boot from the XP cd then ONLY try the following
Click Start.
Click Run.
The Run dialogue box appears.
Type devmgmt.msc in the run dialogue box and click OK.
Click on the plus sign next to DVD/CD ROM Drives.
Locate your DVD/CD ROM drive in the list of devices.
Verify the type of drive in your computer and that the type of media you are using is supported by the drive. Use the table below to determine the supported media types.
DVD+/-RW Read CD or DVD media, write DVD+RW, DVD-RW, DVD+R, DVD-R, CD-R, CD-RW media.
CD-RW/DVD Combination Drive To read CD or DVD media, and write CD media.
DVD-ROM Drive To read CD or DVD media.
CD-RW Drive To read and write CD media.
CD-ROM DRIVE To read CD media.
Try cd drive now before trying the next step
Click the Start button, right-click My Computer, and click Manage.
The Computer Management window appears.
Click Device Manager.
Click the (+) plus IDE controllers section.
Double-click the appropriate IDE channel.
The IDE Channel Properties window appears.
Under the Advanced Settings tab, verify that the transfer mode is set to DMA if available.
Click the OK button to save the change. At this point, you may need to restart for the change to become active.
Check to see if the drive will work in safe mode. I it still does not work Update the firmware for the optical drive.
Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
If all these steps fail then you will need to replace your drive.
Thank you.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
Acer Aspire 5520 CD drive cant read anything
This error message indicates a problem with trying to read or write to a device, such as a hard disk, CD drive, or network drive. This issue may occur for any of the following reasons: Windows is trying to use a transfer mode that the CD drive cannot use.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem, such as a bad cable.
The CD that you are trying to access is damaged.
if that does'nt solve the problem
Try these steps first to see whether they resolve the issue.Restart the computer, and then try the CD again.
Use a cleaner disk to clean the CD Drive.
If you have another computer available to you, try to access the data on the CD with the other computer to make sure that the CD is not damaged. If the CD is inaccessible on the other computer, clean the CD and try again.
If you do not have another computer available, try a different CD in the CD drive to make sure that the problem is with the computer and not with the original CD.
other wise
Method 1: Make sure that all cables are connected correctly
If the CD drive is an external drive, such as a USB device, make sure that the cable that connects the drive to the computer is working correctly. If the cable fails, the CD drive will not function correctly. If you have another cable, try to use it, and also try to connect to another USB port.
Note Changing cables for an internal drive for a desktop computer is recommended only for advanced computer users, because there are many internal items that can be easily damaged. You should not try to change cables inside a laptop or portable computer.
If securing the connection, connecting to another USB port, or using a different cable resolved the issue, you are finished. If this did not resolve the issue, go to method 2.
otherwise
Method 2: Start the computer in a clean boot state
Try to perform a clean boot of the computer to determine whether a program or driver is conflicting with the CD drive
otherwise
Method 3: Change the transfer mode for the CD drive in IDE Channel Properties
If the transfer mode for the CD drive was changed or is incorrect, Windows cannot transfer data from the CD to the computer. You can resolve this issue by changing to the correct transfer mode. To change the transfer mode, follow these steps:Click Start, and then click Run.
Type devmgmt.msc in the Open box, and then press ENTER.
The Device Manager dialog box opens.
Expand IDE ATA/ATAPI controllers. A subset will open, listing the different IDE ATA/ATAPI channels for the computer.
Right-click the channel where the CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
Warning Do not change the Primary IDE Channel, Device 0, because this is typically the system disk. Changing this transfer mode setting may cause the computer to operate incorrectly or not at all.
On the Advanced Settings tab, select PIO Only in the Transfer Mode box for the device that represents the CD drive. Typically, this is Device 0. Then, click OK.
Test the CD in the CD drive.
otherwise
You can check the status of the CD drive in Device Manager to make sure that the device driver is working correctly. If there is a hardware failure or a software conflict preventing the device from operating correctly, usually Device Manager will detect the problem.
otherwise
try access to drive in another comuter
otherwise
replace the cd drive
Mar 25, 2009 | Sony VAIO GRZ660 Notebook
When I put a cd r in my burner then press burn selection then it
Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
www.radarsync.com/
Dec 19, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
TMOUSE (01) error - Win 98 bootup
Try booting using the step-by-step confirmation instead of safe mode. Skip loading the mouse driver that is causing the error. You won't have a mouse when you get booted up but you can use keyboard commands to navigate everything while you try to reload drivers.
Mar 17, 2008 | Toshiba Satellite 4005CDS Notebook
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
HDD OS IS RUNNING IN RECOVERY MODE
After the you sart the system(immediately after detection of ide drives,and boot from cd rom) keep pressing f8..Then from the list choose normal mode..thats all..and yes your cd rom drive wont work in recovery mode
Oct 18, 2007 | Computers & Internet
CD rom
Some CD drives have proprietary drivers but since it worked to install windows, we have a good clue to work with. Check and see if under device manager the IDE channels are working, this means not marked with a yellow exclamation mark. If one or any are, the protected mode drivers are locked. Open regedit and go to this key. HKEY_LOCAL_MACHINE > SYSTEM > CURRENTCONTROLSET > SERVICES > VXD > IOS Click on the NOIDE entry on the right side of the regedit program and hit delete. Close regedit and reboot, this will reset the protected mode drivers. If this doesn't do it, try changing from DMA transfer protocol to P10. It is on the settings page of the CD rom once you get it into device manager. If it's still not working, you may have use DOS mode drivers and that's to complicated to describe here.
Jul 30, 2007 | LG CRD 8481B (CRD-8481B) Internal 48x...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
