Blue color in corner skewed
I have a Toshiba 60" projection TV and recently noticed the blue color in the corner is skewed (looks like you take a straight line and then pull it over) It is only like that in one part of the screen, the corner. The rest is fine. I tried to adjust the colors through the menu screen and when I go to adjust that part of the screen (this model has adjustments for 9 parts of the screen) , the white line has blue to the right on the top and blue to the left on the bottom so you can't adjust it to the cross line.
SOURCE: Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Posted on Sep 07, 2007
Slinteriors
  • 8617 Answers
SOURCE: toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Posted on Jan 20, 2009
ginko
  • 19396 Answers
SOURCE: Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Posted on Mar 10, 2009
SOURCE: Zenith 60'' LCD TV a blue screen is not sky blue it looks dark blue to black
Go to zenith.com, look under the service icon at the top and then you should see a listing for "Class Action Lawsuit/Settlement". If you follow that link, they'll have specifics listed for this suit that was brought against them (including tv model #s included in the suit). There was an agreement reached to fix/replace affected t.v.s, court date was in Feb. I believe, and just waiting now until they post information on how to proceed.
http://www.zenithservice.com/index_b2c.jsp
Good luck and hope that helps.
Posted on Apr 02, 2009
I can see the red blue and green lights on the screen
A better description is needed here:
Picture looks 3d or colors are skewed or screen is overall the wrong color?
May 28, 2012 | Philips Magnavox 9P6034C 60" Rear...
My rear projection tv used to have green lines , now the color seems off and now its blue lines... How do i fix it. Color going out??
If colors are skewed or looks 3d it is a convergence problem.
Some sets when the convergence grid is called up will have green lines--green is fixed and red/blue adjusted to it.
To tell you how to fix I need to know brand and model number.
These are typical convergence problems--no two sets will look exactly the same.
May 16, 2012 | Televison & Video
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Blue section (corner) and blue dots
Hey there Aleman500-
I had this exact same issue with mine. Started noticing the "blue cloud" on the bottom portion of the screen.
Please follow this link and the instructions listed. I opted for an "upgrade" that was offered (brand new 46" bravia lcd) but sony had also offered to fix my tv for free.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDF42WE655&news_id=206
Happy New Year!
Jan 02, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color issue
Replace 120k resistor on the blue video output module. Resistor is located next to the blue video output transistor (has heat sink). If you replace it with a 1/2 watt carbon type, it will probably never happen again. I recomend the same resistor on the red and green video boards at the same time.
Jun 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
