Question about Braun 8585 Electric Shaver
Braun 8585 charger cleaner - not cleaning
The docking unit charges my Braun 8585 but does not clean it -can it be fixed or replaced?
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
Posted on Dec 04, 2009
Make my own cleaning solution for my braun shaver 8585.
It is just an alcohol solution with a very small amount of cleaning solution. A jewelry cleaner premixed would do it.
Nov 20, 2014 | Braun 8585 Electric Shaver
During shaving the shaver makes a loud grating noise. It works fine otherwise. Even during the cleaning cycle, there is a bit more of that noise. Could it need a new battery?
Most likely, the noise is caused by vibration of a broken piece of plastic in the swivel fframe. If this is the case, the part required to fix it for model 8585 can be found at See link below
You will also find an instructional video for disassembly at the link below
Dec 09, 2010 | Braun 8585 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at See link below
Oct 09, 2010 | Braun 8585 Electric Shaver
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at See link below
Sep 25, 2010 | Braun Health & Beauty
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See link below
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
How do you fix the Braun Activator 8585 cleaning base not working?
If the base is not working, there are two possible problems...either the pump is bad or the circuit board is bad. There are no parts available. You will need to purchase a new base. You will find them for sale at See link below
Jul 02, 2010 | Health & Beauty
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
My 8585 braun shaver will not clean the lights flash but nothing
my braun 8585 is five years old and i would like to have it serviced and referbished, please let me know the cost if this is possible?
May 29, 2009 | Braun 8585 Electric Shaver
Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
Nov 25, 2008 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
519 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
