Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chain gear is stripped//garage door opener //lift master 1/3 hp
How did you change the plastic gear?...i looked at it and it does not look that easy to fix.
Thanks
  • Anonymous Dec 20, 2008
    i had the same problem. i got a repair kit from sears that fit my model no. it took about an hour to replace all the gears. i put everything back together and it is doing the same thing. anyone have any suggestions.
    Problem Solver:
  • 16 Answers
I made a webpage that includes the instructions that come with the gear kit. How to replace the gears, reset the travel settings, lots of pictures, part lists and numbers.
http://tinyurl.com/gearfix
chain gear is stripped//garage door opener //lift  - cb953ba.jpg
Posted on Mar 29, 2010
When I push the button to open my garage door, the
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is probably stripped. It is a good time to release the door from the opener and try raising it by hand. Your door springs may be weak or possibly broken.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door does not function makes couple of buzzing sounds only
Remove the cover and check out the drive gear. It is white nylon and is probably stripped.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our Lift-Master Garage Door Opener Model 1265 Gear broke off the sprocket assembly. How hard is it to just replace the part? How is it done? Is it even worth fixing it, or should I just buy a whole new...
vheuser1 is right. I ordered the gear kit (41A2817) for ~$30. Mind you, I only changed one stripped gear so the job was very easy with the right tools, nothing special. Many of my neighbors are having the same problem since our houses were built at the same time but they chose to call in repairmen.
Don't forget to adjust the 4 speed and limit settings once you're done. This was also a good opportunity for me to adjust the slack in my chain since it was hanging too low.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? ...
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a lift master 1/3 HP and when I turn the motor on,
You gear is stripped out on the inside. If your feeling handle you can change it your self open up the case and you will se what I mean right away. Take the gear off and go down to sears they have a part that will work for your opener. make sure to have the opener and chain in the down postion.
liftmaster/sears/chamerlain are all made by the same company so many of there parts work together. But now all of them
Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door model PD200
Take the back cover off and see if the Gear that turns the shaft that operates the chain to lift or close is in good condition.
The gear is probably plastic and 3" or 4" in diameter.
UNPLUG THE OPENER AND DISCONNECT THE POWER BEFORE DOING THE ABOVE.SAFETY IS ALWAYS FIRST.
Jan 16, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,993 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
